A little Hot?!? Hydraulic cooling 4.7 - JeepForum.com
post #1 of 18 Old 10-08-2013, 09:28 AM Thread Starter
Galaxie500LTD
Wj A little Hot?!? Hydraulic cooling 4.7
Well, I've done:
-New Rad
-Complete with OCD coolant flush, running Mopar HOAT now.
-Water pump gasket. Allowed me to check the pump and it's all good
-New thermostat from Mopar and a new rad cap
-PS fluid change. Sucked out fluid with a turkey baster, refilled + repeat many times. Bled air by raising front tires off the ground and did the stop to stop turn thing. Running correct mopar fluid
-Trans fluid change with new filters
My Jeep runs at 203 pretty much all the time. Gauge sits just below the middle mark on the dash. I use my climate control to see the digital readout of the temp.
-Twice this past summer it crawled up to 223+. Once after getting off the highway during a 96 degree day with massive humidity (making it feel like 120) in a parking lot. I thought the temp looked high on the dash, so I popped on my digital display and watched it go from 117 to over 220 and keep climbing. I hopped out and looked under the hood. My cooling fan was spinning, but not WAILING. It was faster than normal, but I thought it should be faster...
I shut down and went and did some shopping. Came back and started it up, temp was 117 hit the HWY and right back to 203
-Second time was in heavy traffic in the city on another hot day. Temp just kept going up and was around 223 and rising, but then the traffic broke and when I got moving again, the temp went back down.
-Is this normal??? Shouldn't my cooling fan be able to handle these hot situations by speeding up and compensating?? I'm worried that if I hadn't gotten out of that traffic jam the temp would have just kept climbing....
What temp does your hydraulic fan start to really come on strong? Does your 4.7 ever get above 225?
Thanks for reading my post guys, any insight as always, is much appreciated.
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline
post #2 of 18 Old 10-08-2013, 09:36 AM
swkenobi
2003 WJ
I wouldn't worry too much, every now and then in heavy traffic mine will creep up the the mid line. Goes back down after a little on its own. I do worry about it given all the talk here about the 4.7 and temps but the fan runs fine and it never goes above the mid line.
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline
post #3 of 18 Old 10-08-2013, 10:24 AM
Jeeples
Jeeples's Avatar
Sounds perfectly normal to me.
Have you checked your A/C condenser for blockage/crushed fins? Maybe its time to look at an external transmission cooler, as this will keep some heat out of the radiator.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 18 Old 10-08-2013, 10:27 AM
Bandit84
Mine goes to the next line after 210 before the fan will kick on. Usually if I'm sitting in traffic or stoplights sometimes. Never goes higher.
85' CJ7
Bandit84 is offline
post #5 of 18 Old 10-08-2013, 10:33 AM
Bandit84
Not to change subject but how to you check the engine temp with the AZC? I'm curious.
85' CJ7
Bandit84 is offline
post #6 of 18 Old 10-10-2013, 09:50 AM Thread Starter
Galaxie500LTD
It's a cool feature. You can use your AZC to check for fault codes in your blend doors:
http://www.wjjeeps.com/climate.htm
When you're in that mode you can turn the passenger temp dial and see numbers up to 99 when you rotate. Put it to 66, then push the re-circ button, you will see your internal engine temp.
You can also use it to see your MPH, RPMS, Ambient under hood temp and some other stuff.... it's pretty nifty
post #7 of 18 Old 10-10-2013, 09:58 AM Thread Starter
Galaxie500LTD
And that's what worries me about mine... it does go higher...
After one hot ride, I forgot to add... on re-start my PS pump was moaning a bit, when I took off the cap... it POPPED with some pressure, then was quiet....
post #8 of 18 Old 10-10-2013, 11:50 AM
3JsWJ
How high does it go? When I'm pulling a trailer with mine and climbing a long hill the temp will creep up past the 210 mark to ~225-230 maybe. Then, the fan must kick on high and it drops back down below 210. It was making me nervous but once I realized it always dropped back down, I don't watch it anymore.
I went as far as changing thermostat, water pump, flushing rad, HOAT with Distilled water, and a new rad cap. Nothing made a difference.
If it doesn't go past 230, I would think that is normal operation.
04 WJ-4.7, 242HD, JK D44, JK HP30, 4" IRO, LSR Bumper, Warn M8000, 33" MTZ
03 WJ-SOLD
3JsWJ is offline
post #9 of 18 Old 10-10-2013, 12:41 PM Thread Starter
Galaxie500LTD
Well it's been up to 225 and the fan doesn't go really fast, like I think it should... that's what worries me. The fan just seems to be going slightly faster, but not wailing.
I guess I'll just have to see what happens if it gets up to 230.
I'm just used to my other vehicles maintaining a pretty steady temp. Like my Galaxie will go to 195 but no higher, no matter what the temp is outside.
post #10 of 18 Old 10-10-2013, 02:13 PM
pinky2252s
It seems like you are barely on the higher side of the normal running temperature. With my scanner, mine will run from 201-224 on a hot day. I have my alarm set for 227. I always think its going to get higher than 224 but it usually backs down. When my scanner says 224 the dash guage is barely over the 210 mark.
I have a new radiator, new water pump, thermostat, hoses, and im running Zerex G-05. Stock hydro fan and power steering pump.
Engine oil also cools the engine, I notice mine runs 2 or 3 degrees cooler after an oil change. Are you close to the oil change time?
You should be fine, the numbers are in the normal range. Just always watch and make sure it doesnt creep up too high!
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #11 of 18 Old 10-10-2013, 02:24 PM
Jeeples
Jeeples's Avatar
Next time you notice the temp creep up, crank up the heater. If the temps drop and stay steady, it might be an indicator that your new radiator has some issues. If it's an aftermarket replacement, perhaps there is a better quality one you can use.
Jeeples is offline
post #12 of 18 Old 10-10-2013, 05:03 PM
86cj74.2L
86cj74.2L's Avatar
With engine up to temp pull the ECT sensor and see if your hydro fan goes into airplane mode.
Do you hear or see it speed up (hydro fan) when you turn on AC?
86cj74.2L is offline
post #13 of 18 Old 10-10-2013, 10:03 PM Thread Starter
Galaxie500LTD
Well that makes me feel a bit better.
Only 800 Miles since my last oil change. I never even go over 3000 miles between changes anyway. Running Mobil 1 synthetic and a purolator filter.
I'll try that. I put in a Spectra brand rad. Looked and fit just like the one I replaced. Has a lifetime warranty.
I'll try that too. I've tried putting on the AC when up to operating temp and the fan speed doesn't seem to change....
I may try pulling the temp sensor off when the motors cold, I did that a year ago and the fan went to WAIL mode. I hope it does it again.
post #14 of 18 Old 10-11-2013, 12:09 AM
86cj74.2L
86cj74.2L's Avatar
Is your AC cold? Errr or was it cold in the summer when the temps creeped up?
I'd be curious to have a scantool that reads live data and compare engine temp to what your seeing on the climate control.
Know what? I can do that with my scanner and Grammys 04 limited............
post #15 of 18 Old 10-11-2013, 06:28 AM Thread Starter
Galaxie500LTD
As a matter of fact... my AC was barely working during that heat wave on the HWY... now I don't think I have AC at all.
