Limited Setnry Security reset - JeepForum.com
post #1 of 3 Old 10-18-2003, 09:26 PM Thread Starter
4cherokee
4cherokee's Avatar
Limited Sentry Security reset
Found a key under the dash of my Limited which I just bought used. Tried it and the chips obviously didn't match. Need to reset the Sentry Security system on my 2000 Grand Cherokee Limited. Starts for 2 seconds and then stops. Nothing in the owners manual on the procedure. Can someone help!!
4cherokee is offline
post #2 of 3 Old 10-20-2003, 11:24 AM Thread Starter
4cherokee
4cherokee's Avatar
Firgured this one out myself...after closer examination of the area where I found the taped key, I discovered that the taped in key is acutally providing the chip code for the sentry system. It is taped into a sensor. After placing the key back into the sensor and retaping it, my beast fired up and is running fine. You would think that with all the sophistication that is in these cars, they would think of something a little more sophisticated than a key and some electrical tape.
post #3 of 3 Old 10-21-2003, 12:59 PM
jiggajeeps
Did it have a remote start? I've heard that when an aftermarket remote start is installed on a vehicle with some sort of sentry key, the installer must wire an extra key under the dash. This key fools the sentry system into thinking that a key is in the ignition during remote starting.
Just a thought.
Current:
'98 TJ SE, stock
Past:
'04 KJ Sport, '98 5.9 Deep Slate, FIPK2, Mopar ECU, '93 XJ Country, '92 YJ 4.0 5speed
jiggajeeps is offline
93 Grand Cherokee Limited Security System Disable HalfShaft ZJ Grand Cherokee Forum 73 01-08-2017 11:24 AM
93 Grand Cherokee Limited 4.0 wont start... Electrical? Security? 93volsd ZJ Grand Cherokee Forum 13 02-22-2009 09:17 PM
IAC reset help Yardman Harry ZJ Grand Cherokee Forum 3 09-30-2007 06:29 PM
How to reset ECU mdevinc ZJ Grand Cherokee Forum 8 06-06-2005 07:59 PM
04 Limited comp. reset? budzilla ZJ Grand Cherokee Forum 4 03-07-2005 07:59 AM
