Liftgate glass - JeepForum.com
post #1 of 7 Old 03-04-2014, 09:35 AM Thread Starter
MarkBlair
Liftgate glass
Probably a stupid question but I've had my wj since december, and I've noticed that if I lock my doors, when I unlock it the Liftgate glass opens, and I have to get out and shut it. Is this normal? It's a pain and I've resorted to not locking my car anymore.
MarkBlair is offline
post #2 of 7 Old 03-04-2014, 09:40 AM
pmdowd6
No that is not normal
pmdowd6 is offline
post #3 of 7 Old 03-04-2014, 09:46 AM
fast540
None of the 3 wj I've owned do that
fast540 is offline
post #4 of 7 Old 03-04-2014, 09:48 AM
gcjeeping
gcjeeping's Avatar
Not normal. Worst case if you cant figure it out is to pull the hatch panel and unplug the switch to stop it opening.
Good luck.
_____________
gcjeeping is offline
post #5 of 7 Old 03-04-2014, 11:33 AM Thread Starter
MarkBlair
Originally Posted by gcjeeping
Not normal. Worst case if you cant figure it out is to pull the hatch panel and unplug the switch to stop it opening. Good luck. .
The button above My license plate doesn't work, just found this out. I have no idea what could causing it to open when I unlock the car
post #6 of 7 Old 03-04-2014, 12:02 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
If the button above the plate doesn't work it might be latch related. Pull the inside trim panel and see whats happening. Maybe the latch just needs some PB blaster or WD40.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #7 of 7 Old 03-04-2014, 05:08 PM
Double E
Double E's Avatar
I wonder if there's a short in that wiring such that when the lock is actuated, it's shorting to energize the push button that does not work normally.
To see if they are related hold in the push button to see if the glass still unlatches when you unlock the vehicle. That will tell you if the switch is still in the circuit but the wiring is at issue..... I bet it does not open the glass but it does sound like you're going to make a visit to the insides of the hatch.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
