Lift Question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Lift Question.
Oconeeoffroad.com Blowing out inventory at special pricesRubicon express discounts from oconee off-roadGreat prices on seating!--Oconee Off-Road
Unread 06-03-2012, 05:14 PM   #1
88yjproject
Lift Question.
Ok I've searched a lot on this. I picked up some cheap 31x10.50 15 Km2's from my buddy. about 1,000 miles on them. Baught some cragar soft 8's with 4" backspacing. Ground my calipers a little to clear. Put jeep back on the ground and the tires rub the fascia and hit the splash gaurd. I have IRO 3" springs, JKS front adj trac bar. I will trim a little from the fascia but I don't want to cut apart the splash shield. Loking at going to 4" if I have to. What are you guys running and how did you fix the rubbing? Thanks guys. I've seen the chart for lift also. I'm currently running LT245/75r16 mt with no rubbing.
2002 WJ 4.0 4.5" Teraflex, Bilstein shocks. Midland CB. 31x10.5x15 Cragar Soft 8's with 4" BS.
HydroLocked Offroad
88yjproject is offline   Reply With Quote
Unread 06-03-2012, 05:38 PM   #2
MuddyWJ
I had to cut the splash guard and I'm running IROs 3in with 255/75/17 BFG MTs not much but had to do it because when you cut that part of the bumper it hangs down.
MuddyWJ is online now   Reply With Quote
Unread 06-04-2012, 04:01 PM   #3
88yjproject
Anyone else have this. Thanks MuddyWJ for your reply.
HydroLocked Offroad
