lift kit and spacer question - JeepForum.com
post #1 of 9 Old 03-20-2012, 01:30 AM Thread Starter
ozgrand
Would there be any problem in putting in a 4" lift kit with 2" spacers and running 6" shocks?
ozgrand is offline
post #2 of 9 Old 03-20-2012, 06:35 AM
Atwater
I just bought an '01 that has 4" springs with 2" spacer. I know other members have the same setup. I have issues but it is with the short arms. You definitely have to have long arms with a 6" lift.
Atwater is offline
post #3 of 9 Old 03-20-2012, 06:55 AM
Weeder1
You can run that setup just make shure you have fixed lower ca's and adj uppers or bot adj uppers and lowers
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #4 of 9 Old 03-20-2012, 06:58 AM
Gazaway
It will ride like crap.without long arms. But if you don't care. You can get away with aftermarket control arms
1999 Bright Platinum Metallic Laredo WJ 4.0 (SOLD)
2001 Silver Stone Metallic Laredo WJ 4.0- 242, D30/D35, BB, Trimmed Bumper, and 265/75/16 Buckshot M/T's, Plastidipped Emblems and Grille, Obsidian Audio 15's in a 7 cubic ft ported box tuned to 30Hz, Audiopipe 15001d, Audiopipe 1002, 1/0 gauge wiring.
Gazaway is offline
post #5 of 9 Old 03-20-2012, 06:59 AM
malibubts
Yeah the biggest issue here is that people will try to do that on short arms. That ride will be crazy rough and it can mess with some of your angles and they might be off. Once you get above 4", some would say at 4", you need you need long arms. So as long as you are getting a long arm setup you should be fine. It has been done on short arms but it isn't recommended at all.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #6 of 9 Old 03-20-2012, 07:04 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Just remember, you will have 6" of lift. So everything on this chart needed for 6", you WILL NEED.
~James
ezflip is offline
post #7 of 9 Old 03-20-2012, 08:28 AM
bhicks
I have the 4.5" teraflex springs with the OME 10mm (=.4") up front and am right at 5" on short arms. The ride is okay, but I would definately NOT go any higher with my short arms. With the angle of the arms now, I have little down travel which means poor flex. I eventually plan to go long arms, but it's not in the budget right now. I have the same set up in the rear PLUS the KOR 3/4" spacer. With the heavy TAG bumper, spare tire, and trail gear my back end was sagging so I added the spacer. I'm still at 5" of lift in the rear and the ride is still just okay at best.
____________________________________________
Past-SOLD2000 TJ, 4.0, 231HD,4.5" long armed lift, 4.56's, detroits, 35" KM1's
Past-SOLD 2000 XJ auto 242 4.0 6" Full traction long arm, Dana 44's, MTR Kevlar 35's, 4.88s, Detroits
Present- 2002 WJ Overland, 242HD(going in soon) 4.5" Teraflex/JKS lift, JCR Sliders, TAG bumpers, 33" Muds, 17" JK Moabs ( Future- 2012 JK Rubicon)
bhicks is offline
post #8 of 9 Old 03-20-2012, 08:45 AM
Weeder1
No, it wont ride like a caddy, but your lifting something and im shure bigger tires. You can do it, and if your ok with a "jeep" ride then you will be alright. If you get a good set of shocks and adjustables i think it would be alright, because i know good long arms get pricey, quick.
-98 xj sport-
Weeder1 is offline
post #9 of 9 Old 03-20-2012, 10:33 AM
spanky02
I added 2in spacers to my 4in kit. It wasn't terrible at first then I started to get death wobble! I now have long arms.. Much better! Lol
99 laredo arb, warn winch, 6 inch iro, long armed, 33s. sold
02 limited bb. sold
04 laredo bb
spanky02 is offline
Spacer lift?? chinin WJ Grand Cherokee Forum 3 03-04-2012 02:25 AM
Spacer Lift Questions WreckMaster WJ Grand Cherokee Forum 13 01-16-2012 09:05 PM
Small lift and spacer question LemonPepper WJ Grand Cherokee Forum 9 10-01-2011 08:02 PM
Do i need A-Arm Spacer if Im at 3" lift? blazepsi WJ Grand Cherokee Forum 10 11-17-2010 05:12 AM
lift spacer straty1987 WJ Grand Cherokee Forum 5 04-28-2010 11:18 PM
