lift kit questions? - JeepForum.com
post #1 of 26 Old 12-18-2013, 11:36 AM Thread Starter
99WJLimited
lift kit questions?
Hello everyone I have been looking at a 4" lift kit by rough country but cannot figure out why they say it won't work for all wheel drive. Can anyone explains this to me please
Here is the link
http://www.roughcountry.com/jeep-sus...-kit-698s.html
99 Grand Cherokee Limited 4.7 45RFE Quadra-Trac II Dana 30 Dana 35 Firestone Destination A/T 245/70R/16
“If I had no sense of humor, I would long ago have committed suicide.” ― Mahatma Gandhi
99WJLimited is offline
post #2 of 26 Old 12-18-2013, 12:11 PM
brouwmat
I don't think there is technically anything that would stop that other than that your front DS is probably a repezza-repezza and won't last long.
Look up CCOR here on the site for more onfo.. that is where I bought mine. Send them a PM.
Sent from AutoGuide.com Free App
brouwmat is offline
post #3 of 26 Old 12-18-2013, 12:13 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Here is the link
Most kits will have something similar written into the fine print. The reason is that lifting puts your drive shafts at less than optimal angles. So they are 'warning' you to cover their own *** in case yours fails shortly after lifting.
~James
ezflip is offline
post #4 of 26 Old 12-18-2013, 12:19 PM
rdkendrick
2003 WJ
It even says not for AWD on the 2" lift kits on Rock Auto. I don't think there are any near extreme angles on a 2" BB.
Sent from my iPad using my fingers
rdkendrick is offline
post #5 of 26 Old 12-18-2013, 12:23 PM Thread Starter
99WJLimited
Yeah I didn't think there was any design issues that would cause it not to work on the awd models. Now just to figure out what vibration they are referring to also lol
post #6 of 26 Old 12-18-2013, 12:24 PM Thread Starter
99WJLimited
Repezza?
post #7 of 26 Old 12-18-2013, 06:07 PM
PowderHound
2003 WJ
Here you go. Your 99 most likely has the weak repezza unless it was replaced already
2003 WJ♦Inferno Red Limited(4.7 H.O., Vari-Lok axles)♦OME HD/BILLY 5100’S♦IRO t-case skid, adj. tb, sway links♦Moog SS♦Factory tow package w/harness & tow hooks♦ Amp/12” sub box♦new bad b**ch passenger♦1993 XJ country♦lift/muds/winchbumper-sold♦build thread instead of long A$$ sig soon...
PowderHound is offline
post #8 of 26 Old 12-18-2013, 06:10 PM
Eshindi
AWD means that there is torque on both your front and rear driveshafts at all times.
If you have a repezza or CV style front drive shaft your best bet is to replace it.
99 WJlimited chances are you have the repezza style driveshaft. Repezza's fail fast when their angle is changed. Regular U jointed Driveshafts will last longer.
Top is Repezza. Bottom is U joint / Double Cardon.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #9 of 26 Old 12-18-2013, 06:23 PM Thread Starter
99WJLimited
So if I replace the shaft I sound be good? What is the price to do so and what kind of a pain in the a$$ will that be?
post #10 of 26 Old 12-18-2013, 06:45 PM
PowderHound
2003 WJ
Yep. All good after replacement. Look on craigslist or a junkyard. Or you can get a new expensive one from tom woods carolina or iron rock. The pita factor depends on rust. Spray with pb blaster a few days before and you will be all good.
post #11 of 26 Old 12-18-2013, 06:57 PM
brouwmat
Junkyard is by far the cheapest. I have about $100 in mine and I rebuilt it myself in the garage with hand tools.
brouwmat is offline
post #12 of 26 Old 12-18-2013, 07:57 PM
WJChris01
If you have a rezeppa, it's not as simple as just replacing the shaft with a double cardan one. You also have to replace the yokes at the diff and the tcase.
- 2001 WJ Laredo
4.0, d30/d35(for now) and 242
3" OME lift with JK Rubicon Moabs and 255/75/17 BFG MT's
- 1998 XJ Sport
Bone stock for now......
WJChris01 is offline
post #13 of 26 Old 12-18-2013, 07:58 PM
Eshindi
That can be a b*tch without a good puller tool
Eshindi is offline
post #14 of 26 Old 12-18-2013, 08:09 PM Thread Starter
99WJLimited
So this $500 kit is sounding over $1000 to me
post #15 of 26 Old 12-18-2013, 08:27 PM
PowderHound
2003 WJ
You really don't want to lift your dub 4" for $500... A budget boost and good shocks along with a drive shaft would cost more than that. Be patient and do it right the first time. You will be happier with something functional instead of something you keep having to throw money at. How many miles are on the 99? Just lookin out dude.
