Left Turn Signal stopped working.... - JeepForum.com
post #1 of 18 Old 03-24-2011, 05:38 PM Thread Starter
HondaPeople
I know there has been some resent write up's regarding the turn signals not working and such and I think I recall seeing something awhile back about this but haven't been able to find it. My hazard lights and right turn signal work just fine, but the left won't. The only way I can get the left one to work is if I briefly turn on the hazard lights--then it will work for a blink or two than stop.
Is the fix removing the combination relay and replacing it/re-soldering it? Or is this a problem in the turn signal stalk itself?
Thanks in advance!
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline
post #2 of 18 Old 03-24-2011, 06:48 PM
jemrey81
jemrey81 is offline
post #3 of 18 Old 03-24-2011, 06:49 PM
jemrey81
forgot to mention.... you can either repair the relay or replace it....... that link gives you all the info.
jemrey81 is offline
post #4 of 18 Old 03-24-2011, 06:58 PM Thread Starter
HondaPeople
Thank you!!
post #5 of 18 Old 03-24-2011, 08:37 PM
jemrey81
happy to help
jemrey81 is offline
post #6 of 18 Old 03-26-2011, 09:54 PM Thread Starter
HondaPeople
I have to be honest.... I took the thing apart and don't see ANY cracks in the solder. I even have a magnifying glass and don't see any. Where would the cracks be? Thanks in advanced!
post #7 of 18 Old 03-26-2011, 10:01 PM
narnwv
narnwv's Avatar
it's along the straight row of contacts on the end. That's where the external contacts connect to the PCB. There's a picture on wjjeeps.com showing it, but I can't find it....
~Aaron
narnwv is offline
post #8 of 18 Old 03-26-2011, 10:47 PM Thread Starter
HondaPeople
Thank you for your input narnwv. But I'm just not seeing it. I've included a picture of what I am looking at.
post #9 of 18 Old 03-26-2011, 10:48 PM
iluvtruenos
1996-2000 Dodge Grand Caravan/Plymouth/Chrysler uses the same part.
At my junkyard they either sell relays (any) at $0.99 apiece or free with a reasonable purchase. For me it was easier to just swap it out rather than trying to fix the damn thing.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #10 of 18 Old 03-26-2011, 10:50 PM
narnwv
narnwv's Avatar
Yes, the 9 pins straight across the top. Horrible picture, but I can setill see that the second one from the left has a "lighter, more porous" tint to it--betcha a dollar if that was heated with a $8 soldering iron from Radio Shack it'd be good as new.
Mine completely quit working and I had to do the left most 3.
There is a picture/write up on wjjeeps.com I swear.
You know what.....the FAQ!
http://www.jeepforum.com/forum/f310/...29/index5.html
~Aaron
narnwv is offline
post #11 of 18 Old 03-26-2011, 10:52 PM Thread Starter
HondaPeople
Thank you narnwv. I appreciate your help and insight.
post #12 of 18 Old 03-26-2011, 10:54 PM
narnwv
narnwv's Avatar
np.
I've done it to mine + 3 other people's WJs.
~Aaron
narnwv is offline
post #13 of 18 Old 09-02-2012, 03:58 PM
cbailey_21
I just replaced the relay and my turn signals still won't work
Originally Posted by smuggler View Post
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #14 of 18 Old 09-02-2012, 10:46 PM
AndyL
do your hazards work?
Sometimes i cycle the hazard switch and then the turn signals work or smacking the top of the dash on the left.
AndyL is offline
post #15 of 18 Old 09-03-2012, 08:37 AM
cbailey_21
Yes my hazards work fine, I Ordered a new turn signal/ head light switch in hopes that it cures my problem
2003 Grand Cherokee Limited blower stopped working Acjeep11566 WJ Grand Cherokee Forum 6 08-19-2014 03:02 PM
horn stopped working!!!! bustaone WJ Grand Cherokee Forum 3 02-02-2011 08:05 AM
My heater stopped working any ideas?? happy1426 WJ Grand Cherokee Forum 0 12-19-2010 06:44 PM
Left turn signal not working on my 99 WJ jtsjeep99 WJ Grand Cherokee Forum 3 03-30-2010 09:32 PM
Left turn signal wont work...sometimes 02HOWJ WJ Grand Cherokee Forum 2 03-14-2010 10:45 PM
