Left turn signal not working on my 99 WJ - JeepForum.com
post #1 of 4 Old 03-30-2010, 07:00 PM Thread Starter
jtsjeep99
Went to use the left turn signal today while driving and it blinked 2 times then stopped. Each time I would turn it on for about 8 times it blinked twice and then stopped. Then it quite all together. The right side works fine and I can hear the relay clicking. When I turn on the flashers only the right side works and not the left. I have replaced all the bulbs front and rear on the left side and no luck. The brake and parking lights work fine, its just the left turn signal. Is it possible for a bad relay to only affect one side? Or do I have a wiring problem?
JTsJeep99
jtsjeep99 is offline
post #2 of 4 Old 03-30-2010, 07:06 PM
straty1987
take the bulb socket out and check the connection point in the housing and on the socket. might have to just scrap then a bit and lift up the tabs a bit in the housing for the turn signal bulb on the left side. worked for mine and a few other people i know only other thing might be a bad wire or bad housing
straty1987 is offline
post #3 of 4 Old 03-30-2010, 08:08 PM Thread Starter
jtsjeep99
I'll try that tomorrow.
JTsJeep99
post #4 of 4 Old 03-30-2010, 09:32 PM Thread Starter
jtsjeep99
Got bored and decided to swap out the relay from one WJ to the other. That was the problem. Thank God! I was dreading tracking down a bad wire. Now I have to order one from the stealership cause I hear that's the only place to get one.
JTsJeep99
Left turn signal stays on Germerican WJ Grand Cherokee Forum 15 06-17-2016 11:44 AM
Left turn signal problem Cons ZJ Grand Cherokee Forum 11 04-02-2010 10:53 AM
Left turn signal MNWJ ZJ Grand Cherokee Forum 6 01-12-2010 08:18 AM
2000 GC left turn signal not working all the time masonater84 ZJ Grand Cherokee Forum 2 10-15-2008 06:21 PM
left turn signal on? tylem28 ZJ Grand Cherokee Forum 2 08-28-2008 01:58 PM
