LED lighted cup holder for WJ (1999-2004) - Page 5 - JeepForum.com
post #61 of 104 Old 08-20-2013, 06:01 AM
cr8zynelly
Originally Posted by its-me-B
There is an on off switch built into the little controller... if you hold the center button down for a couple seconds it will turn off, so I didn't add a switch
Did not know that. Learn something new everyday.
cr8zynelly is offline
post #62 of 104 Old 08-21-2013, 10:01 AM
elcorvino
2003 WJ
Originally Posted by cr8zynelly
Just like this.
How exactly did you get that in there? I connected mine directly to the back of the cigarette lighter, and sometimes the wires get burning hot. I don't know why it's pulling to much. It's connected to speaker wire.
It worked great all night. Now today it wants to get so hot that its pretty much melting the speaker wire. Only the the switch. After that everything is good.
elcorvino is offline
post #63 of 104 Old 08-21-2013, 11:49 AM
cr8zynelly
Pulled the fuse. Stripped the end of the wire. Push/plugged end of the wire in. Put the fuse back in.
post #64 of 104 Old 08-22-2013, 01:48 PM
elcorvino
2003 WJ
Sucks having big hands and not being able to get into tight places. Lol
post #65 of 104 Old 08-22-2013, 11:10 PM
elcorvino
2003 WJ
Can anyone give me insight as to why the speaker wire is getting hot to the point of melting when the lights are on and the cigarette lighter is in use? I understand common sense says its drawing to much power... But why is no one else having this issue? Even if plugging into the fuse box itself instead of connecting at the point of the cigarette lighter, the amount of power being drawn should still run through that point and the speaker wire...
post #66 of 104 Old 08-22-2013, 11:23 PM
rdkendrick
2003 WJ
I don't know. It's just 5 volt LED's and should be pulling only a small amount of amperage. You may want to pm the guy who makes those and ask him. Maybe you got a defective set.
Sent from my iPad using my fingers
rdkendrick is offline
post #67 of 104 Old 08-22-2013, 11:38 PM
elcorvino
2003 WJ
Ok. Made no sense to me. Also, it's only set to blue. None of the buttons work to change colors, intensity, etc. no matter where I pull the power from.
post #68 of 104 Old 08-23-2013, 05:50 AM
its-me-B
You might want to try another power source. When I first hooked mine up it was only white, tried another power wire and was able to change the colors.
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #69 of 104 Old 08-23-2013, 09:59 PM
craigbru
2007 WK
After talking with elcorvino, I'm going to send him a new controller. There should definitely not be any wires getting hot. The controller will get warm, but not uncomfortably so. Out of all the sets that I've sent out, he was unlucky enough to have the only bad controller I know of...
Jeep-Core
craigbru is offline
post #70 of 104 Old 08-24-2013, 09:07 AM
elcorvino
2003 WJ
Can't argue that. Does sound about my luck. Haha
post #71 of 104 Old 11-08-2013, 06:54 PM
aralph30
2003 WJ
How much is this
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #72 of 104 Old 11-08-2013, 08:20 PM
rdkendrick
2003 WJ
Originally Posted by aralph30 View Post
How much is this
Pm CRAIGBRU and ask him if he is still making them.
post #73 of 104 Old 11-09-2013, 08:56 AM
DavisI
Just curious, if you leave the controller in an accessible place, can you change the color and intensity whenever you want?
DavisI is offline
post #74 of 104 Old 11-09-2013, 11:12 AM
craigbru
2007 WK
Hey guys, I am still making these. Although I'm currently overhauling my CNC, I should have the new versions in stock some time next week.
To answer your question DavisI, yes, as long as you can access the controller, the color and intensity can be changed at any time.
Jeep-Core
craigbru is offline
post #75 of 104 Old 11-09-2013, 11:13 AM
DavisI
Alright, cool. Ill definitely be picking these up at some point
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
