Leaking coolant.. pic included - JeepForum.com
post #1 of 12 Old 03-15-2014, 03:17 PM Thread Starter
Xeeh
Wj Leaking coolant.. pic included
So I came outside to do something and noticed a big wet spot in the driveway. After getting up under the jeep and looking around I found out where it was coming from. Here's a pic right after I wiped it clean and saw it start coming out again. What all do I need to do to fix this? Is there a gasket that goes there? My guess was drain the coolant and replace a gasket. Is there anything else I need to know?
Xeeh is offline
post #2 of 12 Old 03-15-2014, 03:38 PM
Jer-Bear
That's the thermostat housing. Yes, there is a gasket that goes inside. A lot of guys use RTV on the outside for a better seal but I only use the gasket. There is s bolt on the top and bottom of the housing, 10mm I think. The gasket is pretty cheap at Autozone or O'Reillys, maybe $4. I'd go ahead and replace the thermostat while you have all that off. But remember how it goes in so you don't install backwards! I made that mistake. After draining all the coolant to remove the housing, refill and bleed the system of air once it gets up to operating temperature. The bleeder valve is an allen head on the right side of the engine bay. Be sure not to torque down the two bolts too much so you don't crush the seal. Good luck!
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #3 of 12 Old 03-15-2014, 03:46 PM
bessyboy
Replaced mine not to long ago, very easy just 2 bolts. *make sure your engine is cold before takin it apart* did mine in a hurry after driving aroun for an hour and it didn't feel good
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline
post #4 of 12 Old 03-15-2014, 04:13 PM Thread Starter
Xeeh
You think I should replace the thermostat housing and the thermostat while doing this? The parts are cheap enough
Xeeh is offline
post #5 of 12 Old 03-15-2014, 04:19 PM
bessyboy
Wouldn't hurt I guess
Rusty's 2" BB
bessyboy is offline
post #6 of 12 Old 03-15-2014, 06:16 PM
narnwv
narnwv's Avatar
Warning:
Go to the dealer and get the thermostat. It comes with a gasket, is MOPAR, and was almost $2 cheaper than the sticky Autozone ones.
Edit: Get the thermostat from the dealer since you'll need to go there for coolant anyway.
~Aaron
narnwv is offline
post #7 of 12 Old 03-15-2014, 06:21 PM
pinky2252s
Originally Posted by narnwv View Post
Warning:
Napa sells HOAT
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #8 of 12 Old 03-15-2014, 06:23 PM
narnwv
narnwv's Avatar
Originally Posted by pinky2252s View Post
Napa sells HOAT
Sure, but since he'll need a thermostat anyway--and I've yet to see an aftermarket thermostat work right/fit right on a 4.7, he might as well get "the good stuff" while he's getting the OEM/cheaper thermostat.
~Aaron
narnwv is offline
post #9 of 12 Old 03-15-2014, 06:37 PM
pinky2252s
Ah. As a reference, I used an Advance Auto thermostat about a year ago, and it is holding up just fine. If it ever goes though, ill be sure to get the OEM.
Is it broken?
post #10 of 12 Old 03-15-2014, 07:32 PM Thread Starter
Xeeh
Is it actually cheaper at the dealer? I was gonna get the fluid at NAPA and parts from rockauto, but I guess I'll go check out the dealer monday
Xeeh is offline
post #11 of 12 Old 03-16-2014, 11:31 AM
Jer-Bear
I personally run green coolant in my '02 with a thermostat and thermostat gasket from O'Reilly's for not a bad price. Been running the green stuff for 5+ years with no problem, even took off the water pump to check the timing cover and it looked great. I've had the thermostat and gasket on there for over a year with no problems. That's just me.
Jer-Bear is offline
post #12 of 12 Old 03-17-2014, 12:15 AM
Jeeples
Jeeples's Avatar
Warning:
x2
My local dealer had the thermostat for $17 and some change with the gasket. The local O'Reilly charges $21.99 with the gasket.
FWIW both the Mopar and O'Reilly are manufactured by Motorad in Israel.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
