Leaking coolant - JeepForum.com
post #1 of 3 Old 11-24-2013, 12:53 PM Thread Starter
LI_DSM
Leaking coolant
Today I came out during my lunch break and look underneath the Jeep and see a small puddle of coolant. I got under the car and it's right where the lower rad hose goes into the thermostat housing. It is dry around the rest of the hose and just appears to be leaking at the bottom part. When the car is running it is a constant drop every 2-3 seconds. I'm not sure if I should just replace the lower radiator hose or if this is most likely a case of the water pump about to fail and leaking through the weephole? As I said before, I could not see any coolant anywhere other than the bottom half of the lower rad hose but I'm not sure if this is a common problem. It's a 2002 4.7HO btw.
Thanks!
LI_DSM is offline
post #2 of 3 Old 11-24-2013, 02:43 PM
doorjamm
If you can't see coolant from the weep hole, I would assume its not the pump. How many miles are on it? It could be a thermostat housing leaking if the gasket is bad. Or even the hose is not clamped tight enough. It's best to find the origin of the leak for sure before just doing a hose because you could waste a good amount of money on coolant
doorjamm is offline
post #3 of 3 Old 11-25-2013, 11:56 AM Thread Starter
LI_DSM
I ended up replacing the the radiator, cap, and both lower and upper radiator hoses and all new coolant. I wanted to just get it all done and have peace of mind. Do not want to risk overheating a 4.7
LI_DSM is offline
