LCA - Straight or Angled? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > LCA - Straight or Angled?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 01-29-2012, 06:27 AM   #1
4Doors
I see some adjustable LCAs that are straight, some that are angled. At 4" lift, which will provide the best ride? Can the angled ones still be swapped to the rear like the straight ones can if I ever went long arm someday in the future?
4Doors is offline   Reply With Quote
Unread 01-29-2012, 06:53 AM   #2
Rocklobster
Rocklobster's Avatar
By angled what do you mean, to the side ? That could be for the front to clear larger tires.
What are your plans for your truck? what do you have done to it now?
Rocklobster is offline   Reply With Quote
Unread 01-29-2012, 07:01 AM   #3
4Doors
Scroll to the bottom of Iron Rock Offroad's LCA selection. They offer them straight or with a mandrel bend.
http://www.ironrockoffroad.com/Merch...egory_Code=WSC
As for my plans, I've been thinking more about going to 4" of lift. I would start with adjustable LCAs and then later go to long arms. The LCAs could go to the rear and be matched with IRO's a-arm. Or I might change my mind tomorrow... I'm bad about researching all my options into the ground before spending money.
Unread 01-29-2012, 07:04 AM   #4
silentbob21
this is just based on what I have seen and know... but generally the short arms are straight... and the long arms are angled to clear the factory control arm mounts. High clearance long arms are straight and require more work for installation... so I dont think either is more benefitial straight or bent... but rather depends on the kit and setup.
just my .02
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline   Reply With Quote
Unread 01-29-2012, 07:11 AM   #5
Rocklobster
Ok, here is what I think you should do. (I am doing just this)
Save up your money, do it right the first time, and look at Clayton's 4.5" long arm lift kit. It looks like a lot of money but it's the only one you will ever need to buy.
If you need something less costly to hold you over PM me. I have a complete 4" Rough Country kit for sale.
Unread 01-29-2012, 07:22 AM   #6
silentbob21
just save for the long arms... either Claytons or IRO high clearance... and dont look back.
Unread 01-29-2012, 07:29 AM   #7
ezflip
The only function of the curved CAs is to fit wider tires. Thats it. It does nothing to ride quality or anything else. And yes, they will work on the rear as well.
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's
Build Thread
ezflip is offline   Reply With Quote
Unread 01-29-2012, 08:50 AM   #8
offroading.net
offroading.net's Avatar
The cranked long arms give more clearance on the axle bracket hence more axle droop before catching on the axle
Steve Wright
1999 4litre WG Limited, 4"f-4.5"r IRO springs, IRO front long arms, IRO adjustable rear a-arm & LCAs, IRO adjustable RHD trackbar, 3.91 Diesel Quadradrive axles, 235-85-16 Grabber AT2's Build thread
2001 4litre WG Limited, stock apart from 245-75-16 Grabber AT2s, the wife's Jeep
1990 4litre MJ, work in progress Build thread
steve@offroading.net
www.offroading.net
www.rcmodelflying.com
offroading.net is offline   Reply With Quote
Unread 01-29-2012, 08:50 AM   #9
4Doors
Perfect, this is exactly what I needed to learn. Thanks!
