The "LAST", remote start install into a WJ, thread! - JeepForum.com
post #1 of 4 Old 10-12-2010, 06:56 PM Thread Starter
mr4g63tsi
Wj The "LAST", remote start install into a WJ, thread!
Hey first post here just so I can get this question answered. I need to know if I need JUST the DEI 455J transponder unit to put my Compustar remote start into my 99 WJ limited. It has the Sentry Key so I know I need to get around the SKIM but just can't find out enough about this DEI 455J to answer my own question. Do I need another bypass unit on top of the 455J or not?
mr4g63tsi is offline
post #2 of 4 Old 10-13-2010, 05:06 AM
hamilton5
Just one bypass.
hamilton5 is offline
post #3 of 4 Old 12-14-2012, 01:09 PM
accelr8
I'm in the midst of installing a Viper 5701 in my '03 Overland. The 455J is not a transponder bypass kit; it is a door lock interface kit that eliminates the need to use additional relays and diodes to control the door locks and dome light illumination. If you plan on using the 455J (door lock interface kit) then you also need the 556U (transponder bypass kit). The 556U requires an additional key which is stored in the module, and when you remote start it looks at that module for the key.
There are all-in-one kits that control your door locks and bypass the transponder system, such as the XK531 (which I think is discontinued but I'm sure there is a replacement available). Not too sure on the all-in-one modules since I ended up going for the 455J and 556U. Hope this helps.
accelr8 is offline
post #4 of 4 Old 12-14-2012, 01:45 PM
Thomahawk
I just installed a Viper 5701, i used the Idatalink skim bypass module.
Buildthread
Thomahawk is offline
i promise this isnt another "clunk" thread patrick983 WJ Grand Cherokee Forum 14 09-19-2010 07:24 PM
remote works but WJ alarm doesnt see "unlock"? hup5150 WJ Grand Cherokee Forum 2 05-31-2010 06:13 PM
Factory Remote Start and/or Alarm PS_Jeep WJ Grand Cherokee Forum 0 04-15-2010 08:16 AM
Yet another Gear thread! 32"33" tires. Max78 WJ Grand Cherokee Forum 11 03-30-2010 03:53 PM
Remote Start oilcounter WJ Grand Cherokee Forum 1 05-21-2004 02:15 PM
