Largest tire size for stock 2000 WJ Limited??? - JeepForum.com
post #1 of 22 Old 12-08-2013, 02:46 PM Thread Starter
WJ2000Limited
Wj Largest tire size for stock 2000 WJ Limited???
Hello everyone i am in need of two back tires so i figured i would get all four and go bigger than what i already have (stock goodyear wrangler). So my question is, what is the largest tire size i can put on without causing rubbing and also without a lift ? Thanks everyone
WJ2000Limited is offline
post #2 of 22 Old 12-08-2013, 10:07 PM
00jeepthing
i had 265/75/16 @stock height. running bfg all terrain. before i out a 2.5-2" lift on. i did alittle trimming to front bumper and it only rubbed on full lock on the frame alittle.
00jeepthing is offline
post #3 of 22 Old 12-09-2013, 03:59 AM Thread Starter
WJ2000Limited
Ok, thanks. Will this tire fit my 17 inch rim?
post #4 of 22 Old 12-09-2013, 07:33 AM
jeep-drivin-YZ
^^ No because the 265/75/16 is the rim size.
1999 Grand Cherokee Laredo 4.0L
1999 YZ 250 peak 60HP current HP 0.
jeep-drivin-YZ is offline
post #5 of 22 Old 12-09-2013, 07:41 AM
Thomahawk
30" overall tire size, 255/65/17
Keep in mind That differ tires Are differ size Even in same size width and profile, due to differ thread depth.
Buildthread
Thomahawk is offline
post #6 of 22 Old 12-09-2013, 07:41 AM Thread Starter
WJ2000Limited
so what is the largest tire i can have on my stock wheels?
post #7 of 22 Old 12-09-2013, 07:42 AM Thread Starter
WJ2000Limited
okay thank you
post #8 of 22 Old 12-09-2013, 07:43 AM
Thomahawk
I would say 255/65/17
Max size from factory was 245/70/16 or 245/65/17 about a 29" tire.
Buildthread
post #9 of 22 Old 12-09-2013, 07:43 AM Thread Starter
WJ2000Limited
Any reccomendations? Would like tires that are good offroad and not noisy on street.
post #10 of 22 Old 12-09-2013, 07:46 AM
Thomahawk
General Grabber at2 this is the Girly Jeep, with 255/65/17, minor rub at full lock in reverse, minor trimming needed, or a 1" BB
MB TKO 17x8.5" rims
Buildthread
post #11 of 22 Old 12-09-2013, 07:48 AM Thread Starter
WJ2000Limited
General Grabber at2 this is the Girly Jeep, with 255/65/17, minor rub at gull lock in reverse, minor trimming needed, or a 1" BB
Okay im sort of new with tire sizes, what does 255/65/17 mean
post #12 of 22 Old 12-09-2013, 07:56 AM Thread Starter
WJ2000Limited
Also, ive seen sites saying a 00 Wj has 16 inch rims but mine measure 17
post #13 of 22 Old 12-09-2013, 08:38 AM
Thomahawk
Read size off your tire, That will tell you how big of a rim you got.
Buildthread
post #14 of 22 Old 12-09-2013, 08:40 AM
Thomahawk
255(width in mm)
65(profile/height of sidewall)% off width
17 (rim size)
Buildthread
post #15 of 22 Old 12-09-2013, 08:40 AM Thread Starter
WJ2000Limited
which number?
