laredo plastic rocker trim - JeepForum.com
post #1 of 6 Old 10-01-2011, 09:54 AM Thread Starter
cherokee00SE
Wj laredo plastic rocker trim
hi all,
my limited has recently developed some rust along the rockers due to the lovely michigan winters. i tried allll the rust "stopping" products out there and of course nothing works. so now what i think id like to do is throw some of that laredo plastic trim down there. not the thick part that goes over the doors, just the thin rocker piece. does anyone know where i can buy something like that? online searches havent been too successful. thanks
cherokee00SE is offline
post #2 of 6 Old 10-01-2011, 11:58 AM
ras2001wj
ras2001wj's Avatar
car-part.com
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #3 of 6 Old 10-01-2011, 10:34 PM
Ryan218
get ahold of your local line x shop i work for a line x in lancaster and this is what i did to my jeep when my rockers devolded a rust hole. plan on dooing the door moldings and front and rear bumpers soon as well. more expensive route but with fix the rust for life. covering it will do nothing but spread the rust faster.
86 GT the garage queen. 5 speed, king cobra clutch, 3.55, dynomax ultra fow car back, MGW short throw, chrome cobra r's.
2001 Grand Cherokee Limited .
Ryan218 is offline
post #4 of 6 Old 10-01-2011, 11:19 PM
compcrasher86
Originally Posted by Ryan218 View Post
get ahold of your local line x shop i work for a line x in lancaster and this is what i did to my jeep when my rockers devolded a rust hole.... covering it will do nothing but spread the rust faster.
Dont mean to pester but isnt that exactly what line-x would be doing? I ask because I have soft rockers and am looking for a good solution to stop the rust.
Matt
compcrasher86 is offline
post #5 of 6 Old 10-02-2011, 08:03 PM Thread Starter
cherokee00SE
yeah ive had no luck with bed liner :/ i was PM'ed earlier about a product from eastwood.com called rust converter. he said he had the same winter/salt caused rust and he used this product and covered with color matched paint and has been good for years. sounds like its worth a try, and its $20
post #6 of 6 Old 10-02-2011, 09:03 PM
Ryan218
some yes. it depends what you ask them to do and what your willing to pay, now ive worked at body shops as well and many body shops will refuse to do rocker work because the rust always comes back. this is because there not fixing the inner rust but only the outer rust issue.
line x is a far superior protective coating then anything else out there on the market. nothing you can get in a spray can or gallon can will even come close to as stong as line x is.
linex.com check it out. you would be surprised how many wranglers are out there with the inner tubs that have line x.
what i did for mine and what ive done on many dodges, ford, chevy trucks and a few jeeps have been to grind the rust away to bare metal, then inside the rocker where you WILL find rust on the inside ive cut a larger hole just a rounded wire wheel inside the rocker to get all the lose rust knocked off. then i use por 15 inside the rust hole to prevent it from rusting the inside out again. then chicken wire and duraglass the hole. let it dry sand it smooth and prep the truck or suv to spray line x.
Ryan218 is offline
How do I fix the faded plastic side trim color? 4.0H.O.XJ WJ Grand Cherokee Forum 53 08-30-2014 05:01 AM
Where to get clips for rocker trim etc. Mighty Thor WJ Grand Cherokee Forum 4 07-30-2012 07:48 PM
Laredo & Laredo Sport wyattrhicks WJ Grand Cherokee Forum 1 05-17-2011 07:47 PM
plastic cladding on the Laredo zachk94 WJ Grand Cherokee Forum 4 04-09-2011 12:09 PM
Laredo Side Trim Replacement? ChiefNWA WJ Grand Cherokee Forum 34 09-23-2010 07:09 PM
