KOR bushing install? - JeepForum.com
post #1 of 10 Old 05-15-2013, 01:15 PM Thread Starter
brianestep
Am I stupid, or is there a trick to installing the KOR bushings in the JKS trackbar? I cannot press them in any further than about halfway. I greased them like a maniac and have been pressing/ hammering etc. I dont want to mar them too bad... I also cannot get them out... how does everyone remove them to re-grease? Screwdriver prying is gouging a little... I feel dumb...
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #2 of 10 Old 05-15-2013, 02:12 PM
WJChris
WJChris's Avatar
socket, 2x4 and a hammer. A vice would be better.
Once sleeve is removed, try going in at a slight angle and tapping out one side. after that use a large socket to press out remaining bushing.
I tapped mine for a zirc fitting to re-grease without removal. WARNING: too much grease will deform the bushing and cause it to wear out prematurely. Mine did. File some passageways for the grease to get in to the bushing and relieve the pressure and you should be golden.
WJChris is offline
post #3 of 10 Old 05-15-2013, 02:27 PM Thread Starter
brianestep
Nice... yea I just found a 2x4 in the garage so I'm doing that now... I am also planning on tapping for zerk, but that will be later. Need to make it driveable first
post #4 of 10 Old 05-15-2013, 03:53 PM
CrazyWalnut13
I had to take mine to work to use the 20ton press. I was unable to get them in with either a BFH or my vice.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #5 of 10 Old 05-15-2013, 04:05 PM Thread Starter
brianestep
I don't know if you guys tried this, but it was way easier pushing the bushings in first and then tapping the sleeve through the middle... Like WJChris kinda said... Too much pressure to do one bushing with the sleeve and then the other bushing.
post #6 of 10 Old 07-16-2013, 02:29 PM
wschilawski
did you ever end up putting zerks in? I've been thinking about doing the same because of the crazy creaks and squeaks I get.
Current Build | 08 JKU Sahara
Previous Build | 02 WJ | 2" BDS Lift
wschilawski is offline
post #7 of 10 Old 07-16-2013, 08:49 PM
Jeeples
Jeeples's Avatar
Go to Napa and buy a tube of Sil-Glyde. It's a silicone based lubricant that's safe for urethane and rubber. Take your bushings apart and line them and the track bar eyelets up real well and you'll be good to go.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #8 of 10 Old 07-16-2013, 09:17 PM
TheBoss
I'll have to try this on my Zone swaybar links. They get a bit chatty in the colder months.
TheBoss is offline
post #9 of 10 Old 07-17-2013, 10:54 AM
Merc1973
Mine went in VERY easily, i installed bushings then the sleeve... strange. I may have used a little lithium grease to ease the installation.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #10 of 10 Old 07-20-2013, 11:31 PM Thread Starter
brianestep
Yea SilGlyde for sure. Sprayed em down with it on install, thinking I'd probably end up having to zerk them later, but all is quiet so far. Plus it's so much less messy than blasting them full of grease gun lube.
