Knocking noise from the left rear - JeepForum.com
post #1 of 10 Old 04-24-2010, 11:06 PM Thread Starter
ScotZ
American to the Bone
ScotZ's Avatar
I have a 2004 GC Overland. I have been getting a knocking or bumping noise from the left rear of the Jeep. When it is up on a rack everything seems ok. What could I have missed? The Jeep has 88K miles on it and drives very straight.
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #2 of 10 Old 04-26-2010, 02:34 AM Thread Starter
ScotZ
ScotZ's Avatar
Bump
- Aldous Huxley
ScotZ is offline
post #3 of 10 Old 04-26-2010, 09:50 AM
lazebum
I had a old truck that used to do this and it was rocks in my gas tank. Probally not the same problem but just FYI, children are awsome!!
01 4.0 WJ - Kolak Brake upgrade, Addaco rear sway bar, 3' OME springs, JKS Adj Track Bar, Bilstine Shocks, MOOG Steering Stablizer and TRE's, IRO SYE front kit with a Double Cardan drive shaft, DANA 44a rear swap, booster seat, 7yrold Son, "Don't Tread On Me" Sticker and plates, oh yeah that is how i roll!!
lazebum is offline
post #4 of 10 Old 04-26-2010, 10:07 AM
nick62087
Do you have factory shocks?
Check the shocks, control arm bolts, and the ball joint.
nick62087 is offline
post #5 of 10 Old 04-26-2010, 10:12 AM
iluvtruenos
Well if it drives straight, then a clunking most likely removes the control arms and ball joint from the equation.
Most likely shocks or sway bar links/bushings.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #6 of 10 Old 04-26-2010, 06:17 PM
keith20mm
Check the rear control arm mounting to the frame, each side, and the single ball joint over the differential, using a pry bar.
keith20mm is offline
post #7 of 10 Old 04-26-2010, 06:47 PM
nick62087
mine drives almost perfectly straight and my ball joint is definitely loose
post #8 of 10 Old 04-27-2010, 08:24 AM
NJStriper
2003 WJ
I have the same problem on my 03 WJ Limited 4.7 HO with 85k miles. I was getting that bump/thump noise when going over bumps. I was at a loss because I thought I checked everything. A couple weeks ago when I was rotating tires I noticed the ball joint above the rear differential looked like it had some play. I'm guessing that you prolly have the same problem. I haven't tried to fisx it yet but im assuming it would be a project.
NJStriper is offline
post #9 of 10 Old 04-28-2010, 09:48 PM
seabee_
2003 WJ
Check the shocks in the rear. Grab the shocks and see if you can move or twist them. Look close at the lower bolts and shock mounts. I had to put stainless steel washers between the shocks and mounts to get rid of the play. It eliminated the clunks. Have you replaced the shocks recently. OEM shocks are wider than aftermarket replacements. Also check the ball joint on top of the pumpkin.
seabee_ is offline
post #10 of 10 Old 04-30-2010, 02:13 AM Thread Starter
ScotZ
ScotZ's Avatar
Thanks for all the suggestions.
- Aldous Huxley
ScotZ is offline
2000 WJ: Left rear knocking sound. What do you check? grnamin WJ Grand Cherokee Forum 15 12-03-2012 07:30 PM
Knocking noise from rear buckboy ZJ Grand Cherokee Forum 0 01-29-2009 12:40 PM
Knocking Noise in Left Front ZJeepMI ZJ Grand Cherokee Forum 3 01-03-2009 11:55 AM
knocking noise after rear main seal replace mdjst5 ZJ Grand Cherokee Forum 12 07-30-2008 08:03 PM
Popping noise in left rear wheel UM John ZJ Grand Cherokee Forum 2 06-15-2004 11:13 AM
