Knocking from front axle 2000 WJ limited V8 - JeepForum.com
post #1 of 8 Old 02-03-2012, 01:00 PM Thread Starter
jaws626
So i can hear a slight knock from my front drivers side wheel. I think it started when I was 4 wheeling and it would knock when just going straight. Now I only hear it when I turn to the left. It's a periodic noise and rather quiet. It's more like a click and not like a heavy faulty shock knock. I did my research and im fairly certain it is the cv joint but I'm not really sure and wanted some other opinions. Could it be something else? Thanks for your input =)
jaws626 is offline
post #2 of 8 Old 02-03-2012, 01:43 PM
99WJdan
Sounds like a cv joint. When mine was going out it would make a clinking sound when turning then after awhile it would make it all the time. Check the boots. If they're ripped, its probably the cause.
My quick discos also make a clicking sounds every once and awhile too.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #3 of 8 Old 02-03-2012, 02:18 PM
Terminator2
CV joint. Replacing both CV axle shaft assemblies is about $125 plus labor unless you want to tackle it yourself.
Terminator2 is offline
post #4 of 8 Old 02-03-2012, 05:26 PM Thread Starter
jaws626
Do I have to replace both? I'm pretty sure it's just the left one. I'm doing it myself while I replace the axel seals (they're leaking). I did check the boots. They're not ripped which is why I was unsure if it was the cv axles.
jaws626 is offline
post #5 of 8 Old 02-04-2012, 03:33 PM
Double E
Double E's Avatar
Pull the tire & make sure the brake pads have not seperated form their backings.
Pull the entire caliper to be certain.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #6 of 8 Old 02-05-2012, 01:34 AM Thread Starter
jaws626
Thanks dude, I'll definitly check them out
jaws626 is offline
post #7 of 8 Old 11-05-2012, 12:46 PM
SDT03GCOverland
2003 WJ
Any final resolution update to this one?
2003 Grand Cherokee Overland, 4 inch Rough Country Lift, upgraded to Rusty's Front Long Arm, JKS Adjustable Trac-Bar
SDT03GCOverland is offline
post #8 of 8 Old 12-22-2012, 10:29 AM Thread Starter
jaws626
It wasn't either CV axle. I'm pretty sure it was a failed CV in the front driveshaft.
jaws626 is offline
axle , front , knocking , noise , wj
2000 Jeep Grand Cherokee Limited Quad AWD front end noise whine howl. whalen62 WJ Grand Cherokee Forum 25 12-17-2013 11:46 PM
WJ help need a 2000 grand Cherokee limited front differential dburke16 WJ Grand Cherokee Forum 1 01-05-2012 07:06 AM
Jeep 2000 Grand Cherokee Limited Front differential Needed dburke16 WJ Grand Cherokee Forum 1 01-04-2012 06:34 PM
2000 limited front end noise nappypappy WJ Grand Cherokee Forum 2 07-01-2011 12:35 PM
99 WJ Limited front axle skiebuster WJ Grand Cherokee Forum 2 07-29-2010 01:46 PM
