Knockin sound after wheeling? Uh oh - JeepForum.com
post #1 of 13 Old 02-12-2012, 01:21 PM Thread Starter
Mp5ben
2005 WK
I was wheeling at a new spot with my manager haha and it was muddy with a lot of little potholes every where, the kind where the jeep would flex a lot...if the sway bar was disconnected.. On the road it sounds like something is knocking on the bottom of the body lightly. I recently installed a 2" BB and checked everything I loosened, including the sway bar links and shaked everything under the body to see if I could recreate the sound but couldn't. Any other ideas what it could be? Would bad u joints make the sound? It seeeems like the sound appears on small bumps. Help a WJ owner out?
Thanks,
Ben
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #2 of 13 Old 02-12-2012, 01:26 PM
smuggler
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
smuggler is offline
post #3 of 13 Old 02-12-2012, 01:36 PM
cbailey_21
This response brought joy to my day...
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #4 of 13 Old 02-12-2012, 01:38 PM
gcjeeping
Is the exhaust loose anywhere. Grab a hold of it at different places an try and move it. Mine would at the back where it goes over the rear axle.
_____________
gcjeeping is offline
post #5 of 13 Old 02-12-2012, 01:38 PM
cbailey_21
And im not too knowledgeable about suspensions and clunking noises, maybe check all your control arm bushings and shock bushings?? You may have wallowed them out, Im just guessing into the wind..
post #6 of 13 Old 02-12-2012, 01:46 PM Thread Starter
Mp5ben
2005 WK
I grabbed the exhaust from the back and gave it a good shaking and it didn't make any sound. But I don't think that would make the sound, the sound is like a rock hitting the under body but not loud
Mp5ben is offline
post #7 of 13 Old 02-12-2012, 02:05 PM
cbailey_21
My jeep has this same clunking sound under the shifter/ driver seat whenever it is under 25 degrees... even if the jeep is in park
post #8 of 13 Old 02-12-2012, 05:23 PM Thread Starter
Mp5ben
2005 WK
Hm, just wondering, could this be the A arm messing up? I didn't add an a arm space after my lift
Mp5ben is offline
post #9 of 13 Old 02-12-2012, 05:41 PM
robby65
2007 XK Commander
Check the rear a arm bushings? Maybe the rear ball joint?
robby65 is offline
post #10 of 13 Old 02-12-2012, 10:53 PM
rboots
I just did a bb and had a knocking noise similar to that, ended up being the shock mount on the rear axle that was just not tight enough. bolt was tight but just needed a little more and it went away. Thats my experience
rboots is offline
post #11 of 13 Old 02-13-2012, 09:33 AM Thread Starter
Mp5ben
2005 WK
Damn. I forgot to check the shocks haha. I'll check those as soon as I get back to my Jeep
Mp5ben is offline
post #12 of 13 Old 02-13-2012, 05:11 PM Thread Starter
Mp5ben
2005 WK
Just checked the shocks and tightened them to torque specs. No change. It literally sounds like there's something dangling under the jeep and knocking around. I'm at a loss, my dads going to take it to a shop soon if I can't find the problem
Mp5ben is offline
post #13 of 13 Old 02-13-2012, 05:57 PM Thread Starter
Mp5ben
2005 WK
Found the problem. It was the front sway bar linkage. Don't know how the sound managed to sound like it was coming from the back, but I'm just glad my Jeep isn't broken
Mp5ben is offline
