knock sensors 4.7l H.O. code p0325, anyone? - JeepForum.com
post #1 of 9 Old 01-29-2015, 07:10 PM Thread Starter
r_kelly252
So I've def looked around the forum for the answer to this mystery, and nothing quite like this.
I just picked up an 04 overland. Clean one owner. Really a nice one. A couple flaws I'm starting to notice after driving it home. Grille is not an 04 grille but an older Laredo chrome grille. From like an 01. Kinda weird but whatever. So I decide to do the check engine light/ code thing with the key switch. I mean the light isn't on but maybe they pulled the bulb and its really on? I'm getting a code P0325. And that's it. Knock sensor #1. Anything I have found on the forum has been specific to 0325 & 0330& or 0700. All three codes or at least two. I'm only getting the one.
It drives fine, shifts fine. Power is right on par for the H.O.... Any insight to just one knock sensor that's coding out but yet not triggering the check engine light? Could this be from running 87 octane in the h.o ?
I've thought about going straight to the dealership but other threads I've read they are useless. A lot of JU and JF stuff I found was posted 7-10 years ago. Nothing new on the matter.
Anyone?
r_kelly252 is offline
post #2 of 9 Old 01-29-2015, 07:32 PM
CarlJH
2003 WJ
I too have just got an 03 4.7 HO in December, did the key trick and also got po325 with no CEL.
told the dealer to sort it before I took delivery, when they plugged their snap-on scanner in, it could not find the fault?
Did the key thing again about a week after i got it, and no fault so I think it was just old fuel from not being used for several months
CarlJH is offline
post #3 of 9 Old 01-29-2015, 07:33 PM
mr312712
Yeah I had that code to but since I disconnected the battery a few days ago It hasn't come back.
It doesn't matter If the guy next to you doesn't know your racing winning Is winning.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland Inferno Red 4.7 MAGNUM V8 HIGH OUTPUT
mr312712 is offline
post #4 of 9 Old 01-29-2015, 10:51 PM Thread Starter
r_kelly252
Yeah I thought about old fuel sitting too. I wish I tried checking the codes before I drove it home. I think I'm on my own for the expense to fix. We'll see, I'm hoping to delete it and be alset like you
post #5 of 9 Old 04-01-2015, 10:20 PM
bloke279
bloke279's Avatar
2015 JK Wrangler
Im resurrecting this one.
I am a new owner of an 02 overland. I noticed that the RPM's will waiver about 50 RPM. I replaced the TPS and IAC tonight, for good measure. The RPM's never dropped past 500, usually sat around 650-700. I noticed tonight that I dropped to 400 at one point. It still has the wondering RPM issue. I pulled the codes via odometer, and I have an 0325. I didnt know I had to run premuim fuel, so I am now on my 2nd tank of regular unleaded. Im hoping that filing up with 91 on the next tank will help smooth the idle out. I will say, I didnt notice the wondering RPM on the test drive, and I was listening for everything, as well as the passenger with me. Any thoughts? Are my hopeful desires realistic? Thank you.
PS..
This was not posted without the search function being used prior.
2015 JKU
BB, Rubi wheel/tire, Barricade sliders
Ordered:
Synergy Ball joints, gussets and sleeves
Saving for:
4" short arm, 35's, bumper/carrier, e-locker and gears
bloke279 is offline
post #6 of 9 Old 04-02-2015, 06:57 AM
briandor
Originally Posted by bloke279
Im resurrecting this one. I am a new owner of an 02 overland. I noticed that the RPM's will waiver about 50 RPM. I replaced the TPS and IAC tonight, for good measure. The RPM's never dropped past 500, usually sat around 650-700. I noticed tonight that I dropped to 400 at one point. It still has the wondering RPM issue. I pulled the codes via odometer, and I have an 0325. I didnt know I had to run premuim fuel, so I am now on my 2nd tank of regular unleaded. Im hoping that filing up with 91 on the next tank will help smooth the idle out. I will say, I didnt notice the wondering RPM on the test drive, and I was listening for everything, as well as the passenger with me. Any thoughts? Are my hopeful desires realistic? Thank you. PS.. This was not posted without the search function being used prior.
I have an overland too. You don't "have" to run premium. The specs allow for running regular but to get the higher performance you need to run premium. When you run regular it retards the timing so you don't get optimal hp. I also have the wandering idle and have replaced several sensors as well as cleaned the crap out of the throttle body. It helped a little bit it still wanders.
As far as your knock sensor code it most likely isn't caused by the knock sensors at all. It's more likely that you need to replace your O2 sensors. When they start to go bad the fuel mixture is off a bit which can cause a little pinging and that throws the knock sensor code. Make sure you use Mopar sensors too. First time I replaced them I didn't use Mopar. It ran better but still had a hesitation and the knock code. Replaced them again with Mopar and the hesitation and knock code are gone.
briandor is offline
post #7 of 9 Old 04-03-2015, 10:21 AM Thread Starter
r_kelly252
Never gave 02 sensors a thought.
Yeah just like briandor said, you don't need premium fuel. But it was still a thought that maybe it was kicking the code on.
Haven't tried disconnecting battery but I did in fact run a scan tool on it and I got nothing. But the p0325 code is still in the odometer. I'll try that today, now I have time to figure this out again.
I too have a wandering idle, never concerned me. I figured once knock sensor code was figured out it would fix it. I'd like to fix the idle but...hey its just at idle and its only a mere 50 rpms so I almost don't care.
post #8 of 9 Old 04-03-2015, 12:15 PM
briandor
It seems the wandering idle is a pretty common issue with the 4.7 but for some reason nobody seems to have fixed it or posted how to fix it. Maybe it's like you said, it isn't that big of an issues and more of an annoyance. Most who have the issue probably don't care enough to spend much time to figure it out and fix it. Closest I've come is thinking it is the ECM that is causing it because I also see a wobble of the gauges, in particular the voltage gauge, that seems to go with the wobbling idle.
briandor is offline
post #9 of 9 Old 04-03-2015, 12:17 PM
imaguy3
The output of the alternator is directly proportional to the speed of the alternator. You will not be producing as many volts at idle when compared to driving. Similarly if you idle slower than normal expect to see the voltage drop or jump around with the idle.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
