Just lifted, now the tire questions... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Just lifted, now the tire questions...
2007-2014 Jeep Wrangler Black Sun Shade (Rugged Ridge)2007-2014 Jeep Wrangler Smoked Style Hood Air DeflectorIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-05-2014, 08:25 PM   #1
yellowismellow
rubber duck sicko!
yellowismellow's Avatar
2004 wj with a 4.0 and 247. I just installed 2" IRO springs with new isolators and bilstein 5100 shocks from kolak. Currently I'm running the stock 245/70/16 tires and wheels. Looking for tires to put on a set of JK rubicon rims that I scored for cheap in mint condition.
My question...yes, what the largest tire I can move up to without trimming? From what I see, tires that will equal the circumference of my current tires(245/70/16), would be a 245/65/17. Correct me if I'm wrong on these tire conversions. What size would be best? This wj is 95% street as it's my wife's, yet we use it to haul all my gear when going on long wheeling trips in my TJ. 245/75/17? /255/65/17? 235/75/17?? Also, how bad is the speedometer going to be? I noticed there's not gear to swap out, and is sensored. Not too concerned about being off a mph or 2, more worried about transmission issues arising with a drastic change in size.
Lift install went smoothly. All control arms replaced with stock new replacements, rides great even without getting an alignment for a few days yet.
Here's a pic. What tire would you go with?
Thanks for the advice.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline   Reply With Quote
Unread 05-06-2014, 05:02 AM   #2
yellowismellow
rubber duck sicko!
100 views and no responses? I know this topic is brought up all the time, but help me out guys!
2006 TJ Sport
Unread 05-06-2014, 05:49 AM   #3
braddf
most people say 245/70/17 for that unless you don't offroad much then you could go maybe a tad bigger. 245/70 to be safe tho
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline   Reply With Quote
Unread 05-06-2014, 05:59 AM   #4
HamJam
I have a 3" Iro lift and Jk take offs and run 245/75/17 duratracs and they only rub very slightly in reverse with steering cranked.
HamJam is offline   Reply With Quote
Unread 05-06-2014, 06:22 AM   #5
yellowismellow
rubber duck sicko!
Thanks guys. I'm looking for a decent all terrain tire to stick under her wj
2006 TJ Sport
Unread 05-06-2014, 07:09 AM   #6
PirateB
Toyo open country a/t II great tire!
Sent from my DROID RAZR HD using JeepForum
PirateB is offline   Reply With Quote
Unread 05-06-2014, 07:59 AM   #7
ChrisHager
ChrisHager's Avatar
If you're sticking with stock backspacing, you'll want a 245/75R16 (245/70R17). I went with Goodyear Wrangler DuraTracs in that size and love them. I found my speedometer is now spot on (they typically are not when the vehicle is in stock form).
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is online now   Reply With Quote
Unread 05-06-2014, 12:11 PM   #8
jpat30
I run 245 75 16 KM2 and I found that my speedo is now dead on as well as measured with GPS.
-Carpe Diem Phil 1:20
jpat30 is offline   Reply With Quote
Unread 05-06-2014, 12:25 PM   #9
gold01wj
FYI speed is electronically controlled from the rear abs sensors... A speedo drd or super lift true speed are the best way to fix modern signal fed speedometers... I have the drd on my wj and the true speed on my silverado. Both work great. I think the drd is a bit easier to program tho
2000 wj limited quadradrive 4.7 family vehicle-was stock, then lifted 4",now stock again
gold01wj is offline   Reply With Quote
Unread 05-06-2014, 12:27 PM   #10
poj2001
Thats good to know for those who lift, but kinda crappy for the majority of the world that drives it stock. My 01 WJ speedometer was off by about 3mph with stock tires.
I am picking up an 04 WJ Friday and plan on putting a 2" lift in, good to know 245/70R17 will fix the speedo
poj2001 is offline   Reply With Quote
