Just Fixed my Heated seats! - JeepForum.com
post #1 of 69 Old 12-29-2004, 11:27 AM Thread Starter
Myrtle Beach
Fixed both my heated seats over the holidays. It only took 1 hour per seat and is a pretty easy job. After not having them work for the past three years...I must say, they are awesome. The problem was the same on both seats- the wire for the heating element broke on the side closest to the door. i used the tsb part number to complete the repair ($16 per seat) If anyone needs direction or help with the repair let me know.
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Myrtle Beach is offline
post #2 of 69 Old 12-29-2004, 12:11 PM
Meerkat
And I thought I was a procrastinator!
Good job Myrtle!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 69 Old 12-29-2004, 12:11 PM
squid2004
Might as well post the info while it's fresh in your mind, for the faq at least, I'm sure this will come in handy.
squid2004 is offline
post #4 of 69 Old 12-29-2004, 01:56 PM Thread Starter
Myrtle Beach
-Tilt the seat back and slide forward
-remove the seat (4 bolts)
-disconnect the wiring harness
-remove the plastic cover with the power seat controls
-seperate the seat back from the seat cushion (3 bolts and 2 wirng harness)
-Check the Green wiring harness for continuity to find which element contains the open circuit(using a multi meter)-Most likely the side closest to the door has a broken wire and is causing the problem
-remove 3 hog rings and then carefully work the leather seat cover off the cushion
- cut the old heating wire and remove old harness. apply the new heating element to the cushion ( Since this would way allowed part of the cushion to block the element, I very carefully cut the cushion with a razor blade and installed the new heater on the other side of the cushion--closer to the seat)
---I also used two repair kits per seat so i wouldn;t have to later repair the side closet to the center console, most likely you will just need one per seat though
-reassemble the seat using the hog rings provided
WoLah!-toasty buns
This way the passenger can't complain anymore since the passenger side heat doesn't work either
post #5 of 69 Old 12-29-2004, 02:24 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Originally Posted by Myrtle Beach
... i used the tsb part number to complete the repair ($16 per seat) If anyone needs direction or help with the repair let me know.
I need to do this too, can you call out the TSB # and part #, and where you got them (on-line w/ link, dealer, retail?).
Thanks for the write up. I've been dreading doing this, sounds like I worried over nothing.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #6 of 69 Old 12-29-2004, 02:38 PM Thread Starter
Myrtle Beach
The job wasn't nearly as bad as I thought-It was really pretty easy. I did the first seat by myself, and had help witht he second one (positioning the seat back)
Here is the part i got from the dealer, it was $16. I used two per seat, but you can most likely get by with just one kit per seat. Make sure your jeep's build date is applicable to the TSB!
-5019769AA Heated Seat Repair Kit (One kit per heating element)
0800401B - HEATED SEAT - INOPERATIVE
Date: 12/20/01 (supersedes 0800401A dated 03/01)
Model Year(s): 1999-2002
Description: Heated seat inoperative. On some vehicles the heated seat may be inoperative due to an open circuit in the seat cushion heating element.
Details: This bulletin involves installing a kit to repair an open circuit in the heated seat heating element circuit. Using a digital ohmmeter, check the resistance across the four way heated seat feed connector under the seat. The resistance between terminals “A” and “B”should be 0.90 ohms to 1.90 ohms. If the resistance value falls outside of this range, perform the Repair Procedure.
NOTE: SOME VEHICLES USE CARBON FIBER HEATING ELEMENTS. CARBON FIBER HEATING ELEMENTS HAVE A RESISTANCE OF 10 TO 14 OHMS IN THE BOLSTER ELEMENT. SEATS WITH CARBON FIBER ELEMENTS HAVE TWO CONNECTORS AT THE BACK OF THE SEAT. A TWO WAY CONNECTOR AND A FOUR WAY CONNECTOR. CARBON FIBER HEATING ELEMENTS ARE NOT SERVICEABLE AND REQUIRE REPLACEMENT OF THE SEAT COVER.
Parts required:
5072485AA Heating Element - Seat back (2001 Vehicles, see Note below)
5072486AA Heating Element - Seat cushion (2001 Vehicles, see Note below)
The heated seat repair kit, P/N 05019769AA contains detailed installation instructions. Follow the instructions provided in the kit for installation. Refer to the 2002 Grand Cherokee service manual, publication number 81–370–02064, page 8G-14, for instructions on the replaceable heating elements, P/N 5072485AA and 5072486AA).
NOTES:
1999 Trim code DL: Use 5019769AA on vehicle built before Nov. 17, 1998. Vehicles built after Nov. 17, 1998 - replace seat cover
post #7 of 69 Old 12-29-2004, 04:17 PM
PlatinumZJ
PlatinumZJ's Avatar
Check the build date! Got it, I'll have to research the ZJ stuff a little. But, you have encouraged me to endevor to perservere!
Doug
Links:
for ZJ & WJ stuff,
post #8 of 69 Old 12-29-2004, 05:50 PM
JCDubya
2009 WK
Does the heated seat option only come with leather?
JCDubya is offline
post #9 of 69 Old 12-29-2004, 06:33 PM
Meerkat
I think the heat only comes with Limited's and Limited's only come with leather...
Warren
Meerkat is offline
post #10 of 69 Old 12-29-2004, 06:56 PM
JCDubya
2009 WK
I want heated seats on my SE
JCDubya is offline
post #11 of 69 Old 12-30-2004, 01:34 AM
DanEms
2012 WK
Hey thanks for the info! I'm planning on doing this to my Grand Cherokee Limited as well. Right now I'm debating whether or not to do the TSB on the fuel module myself or letting a shop do it. I bought the parts for the job only $11 but the job itself requires draining and dropping the tank, in order to get to the fuel module. Anyways, I've got a few questions if you don't mind. First, how many heating elements are on each seat? Second, I've read the TSB and it listed part numbers for new heating elements and seat covers, are any of these needed or required for this job? Or can I just order the repair kit? Thanks in advance!
-Dan
DanEms is offline
post #12 of 69 Old 12-30-2004, 07:15 AM Thread Starter
Myrtle Beach
-Dan
It depends what month and year your Jeep was built for the TSB kit. I beleive the seat contains 4 elements all together. one on each side of the seat, a center element, and then one in the seat back. The only part # i used was 5019769AA Heated Seat Repair Kit (1 per seat) to repair the open circuit on the side closest to the door in the seat. I used my original seat covers. Look inside the drivers side door to find your build date and post it. That should let us know if the repair kit is applicable to your jeep
post #13 of 69 Old 12-30-2004, 03:00 PM
DanEms
2012 WK
Hey thanks for the help. My build date is 11/99. So I'm wondering, if I had more than one wire broken for different elements on the same seat, would I still only need one repair kit per seat, or should I purchase more?
Thanks,
Dan
DanEms is offline
post #14 of 69 Old 12-31-2004, 07:22 AM Thread Starter
Myrtle Beach
NOTES:
This makes me wonder if the TSB is for your Jeep. I would take the seat out and check the wiring harness for the continuity with a multi meter. On my seat, the wiring had a green clip. If you have an open circuit i would try to pull the seat cover off and see if you can locate where the wire broke, and solder it OR repair with the kit. Hope this helps
post #15 of 69 Old 12-31-2004, 10:02 PM
nashmd454
nashmd454's Avatar
I guess I am more of a pessimist...it still sounds hard to me...pulling the seats apart and cutting cushion and pulling the leather off and so on. I really don't want to come off as a dumb@#$ but could you PLEASE explain it to me in a easier way than you already did Myrtle.
nashmd454 is offline
Installing heated seats into non heated wj Deah7 ZJ Grand Cherokee Forum 23 10-12-2012 02:08 PM
Just fixed my Heated Seat!!!!! 99WJCHRIS ZJ Grand Cherokee Forum 12 01-22-2010 02:14 PM
Installing 98 ZJ heated seats in a 93 with no power seats aaron7 ZJ Grand Cherokee Forum 4 12-28-2008 11:47 AM
Heated seats 98zjteen ZJ Grand Cherokee Forum 3 11-06-2007 01:49 PM
Heated Seat (97)- Fixed! Izzy ZJ Grand Cherokee Forum 1 03-07-2007 11:25 AM
