04-27-2012, 02:30 PM
#1
Just bought a WJ with engine managment light on
Hi all
After some great advice on here I've put a deposit on a really nice 4.7 limited 2001, 61k, interior mint, parking sensors and infinity gold. Just needs bumpers spraying really.
Anyway she has the engine management light on. She drives really well so I had no problem buying as it was only £2700 (I'm in london) any ideas what this could be? Lambada maybe?
Any advice appreciated
Thanks Gary
04-27-2012, 02:38 PM
#2
I assume that means the check engine light. Hopefully it's only something minor, but you need to have it scanned for codes.
04-27-2012, 02:40 PM
#3
first thing that pops in my head is gas cap. make sure thats secure. some vehicles shine the CEL for a loose gas cap.
head to autozone or something and have them pull some codes.
04-27-2012, 02:48 PM
#4
Doesn't the key dance work ?
04-27-2012, 03:47 PM
#5
What's the key dance?
04-27-2012, 03:48 PM
#6
I'll try the cap thanks
04-27-2012, 03:58 PM
#7
Turn the key to the "on" not "ignition" and do the following:
On,off,on,off,on,off. (3 times on and off). Then your odometer should read "done" and show your current codes. Post what you see here
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
04-27-2012, 04:18 PM
#8
Pinky is close.
on, off, on, off, on. Odometer will read codes (if any) then DONE. Have a pen handy to write down any codes.
04-27-2012, 04:35 PM
#9
Just read the codes using the key trick and stop guessing if its a gas cap or not. Thats what this system is meant for people!!!!!!!!!
04-27-2012, 04:44 PM
#10
 Everyone just wishes it was the gas cap.
04-27-2012, 04:51 PM
#11
indeed.
although, admittedly i didnt know about this trick. only knew about this in LMTV's and such
04-27-2012, 05:37 PM
#12
Hopefully you don't get the "It's time for a new motor P code"
04 Overland on 33's, Lift & tires= 8" over stock.
04-27-2012, 05:50 PM
#13
Originally Posted by TSyl
Pinky is close.
Whooopppsss. You might wanna have it the "on" position to read it huh? Hahaha
Is it broken?
04-27-2012, 05:59 PM
#14
Why don't you just buy a code reader. You'll need it, no question about that.
WJ Grand Cherokee 2002 4.0L
Laredo 249k km,Select Trac
Class III hitch
P245 P70/16 Nokian All Weather Plus tires
04-27-2012, 06:23 PM
#15
...the jeep has a built in code reader. Why would you need to buy one?
Is it broken?
