Just bought my 3rd Jeep! 2004 Jeep Grand Cherokee! - JeepForum.com
post #1 of 8 Old 11-10-2010, 09:13 AM Thread Starter
drew8742
Wj Just bought my 3rd Jeep! 2004 Jeep Grand Cherokee!
I want to do a full tune up on it...all the basic stuff (plugs, royal purple oil changes, fuel filter/regulator, air filter). Is there a PCV valve on the 2004 models? if so can someone paste a link so I can order one.
Any other suggestions to make it run better and get better mileage?
drew8742 is offline
post #2 of 8 Old 11-10-2010, 09:15 AM
compcrasher86
Wellllll, give us some specs. 2004 was the best year for WJs. Do you have the 4.7 or the 4.0? What kind of 4wd does it have, quadra-trac or quadra-drive... unless you got the extremely rare-optioned 4.7 Limited with selec-trac....
you should clean the throttle body, I always like to take it off with the sensors and everything and go through it piece by piece and clean it by hand really well with carb cleaner, especially the IAC and the IAC housing. reinstall with a new gasket.
Also I believe there is a PCV valve on the i6 models, dont quote me on it though. I really dont know enough on the 4.7 to give advice but I do have a FSM if you need anything looked up. Just gimme a shout
Matt
compcrasher86 is offline
post #3 of 8 Old 11-10-2010, 10:04 AM
Best4x4
PCV on the 4.7 is over by the Oil Filler Tube. You can pick one up for around 6.00. If it's the 4.7 stick with the stock Champion plugs. The 4.7 doesn't need anything fancy as far as plugs are concerned unless it's a 4.7 HO. Then like mentioned above I'd fully clean the throttle body. I think the fuel filter is part of the fuel pump so that's one less thing to worry about.
When I bought my 04 with the 4.7 I was amazed at how well it ran with 62K on it. Then I did a complete tune up and it was even better! I've been running full synthetic oil and Mobil1 oil filters as well.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #4 of 8 Old 11-10-2010, 11:33 AM
compcrasher86
4.0 is the same way, stick with basic copper plugs or its gunna run worse Its a jeep thing, designed to save you money for once lol
Matt
post #5 of 8 Old 11-10-2010, 11:37 AM
Best4x4
If it's a distributorless 4.0L then you'd want to run double platinum's. My 4.0L in my 05 Wrangler came with NGK copper core plugs, but I've had much better results with Champion 7034 Double Platinums.
Best4x4 is offline
post #6 of 8 Old 11-11-2010, 03:17 PM Thread Starter
drew8742
sorry it took a while. The specs: 4.0L, 4x4, quadra drive, 86,000 miles.
After some research I did find out that the fuel filter/regulator is no in the gas tank, it's on the frame above the rear axle, driver side. I may replace that also.
I've noticed that I've gone through a half tank of gas already. I bought it monday night (11/8/10 and it's now thursday and i need gas already. I think i should stay with the oem champion copper plugs as recommened on the teamgrandcherokee.com site as well as other oem replacement parts.
In the end, i'd like it to run ni tip-top shape and get better gas mileage, i don't drive with a lead foot either so that helps.
drew8742 is offline
post #7 of 8 Old 11-11-2010, 03:28 PM
compcrasher86
lol well it is a Jeep haha. Fuel filter/regulator has been known to give 2mpg in some cases so definately check that out. Champion copper plugs are what it likes so yeah definately check those out. Half a tank every four days sounds normal for me lol but I drive heavy.
Matt
post #8 of 8 Old 11-11-2010, 04:13 PM
Best4x4
If you're going to stick with copper core plugs go with Champion Truck Plugs 4412, but good luck finding them. Everyone on the TJ forums highly recommends running Champion 7034 double platinum plugs on a distributorless 4.0L straight six. You will get a much cleaner spark and longer life out of the plugs.
Best4x4 is offline
2004 Jeep Grand Cherokee Overland 4.7L HO Loss of Performance / Acceleration Problem DHewes WJ Grand Cherokee Forum 70 03-30-2017 08:51 PM
Just bought a Jeep Grand Cherokee which is throwing multiple codes, 01grandcherokee WJ Grand Cherokee Forum 8 10-29-2010 01:37 PM
2004 Jeep Grand Cherokee---Overheating after water pump replacement! Thoughts? Hundoracer WJ Grand Cherokee Forum 2 07-05-2010 03:22 PM
2004 Jeep Grand Cherokee (WJ) Tire Question paulcicero WJ Grand Cherokee Forum 8 06-30-2010 05:42 PM
Headlights on the 2004 Jeep Grand Cherokee boyandhisjeep WJ Grand Cherokee Forum 1 10-21-2003 01:38 PM
