Johnny Joint tube side upper control arm install - JeepForum.com
post #1 of 7 Old 08-18-2010, 04:43 PM Thread Starter
skain8
skain8's Avatar
Thumbs up Johnny Joint tube side upper control arm install
A bit of background -- my issue was wanting an upgrade for the upper control arm bushings, which I was wearing out a bit too fast for my liking. Not only that, but they are a major PITA to replace. I looked to Currie's Johnny Joint, which others have used as a replacement on the housing side, which is a direct swap with the 2" jj. There is no direct swap for the tube side mount, however. In my opinion, it only makes sense to use either 2 bushings, or 2 jj's, not a combination of both. [IRO long arm users do not have this issue since the "iron y" negates the passenger upper control arm].
Currie joints are arguably the best out there due to quality, strength and the added benefit of 30* of movement over a "fixed" rubber bushing. The natural movement of the joint is good for my set-up as well since Clayton's upper arms are just a tad bit misaligned by the nature of their design (which is probably why I have been eating through upper bushings more rapidly due to the constant preload). The joints do have an interior urethane bushing, and not simply a solid metal joint as some would think. Plus, they are 100% rebuildable in place, which is even better.
Currie makes a bracket piece with the jj welded in place. They market it to TJ's, XJ's, etc... and not to the WJ/ZJ crowd apparently because the tube side upper control arm mount is more narrow. I ordered this anyway and figured I'd make it work:
Note that it comes with an extra 2" jj, which really isn't bad for the total price. (SEE FOR SALE SECTION for my spare 2" JJ )
The piece is solid metal. It is indeed larger than the WJ upper control arm bracket, so I had to shave a bit off 2 sides. That was all the modification it needed. I cut off the existing bracket, leaving 2" of bracket. Placed the Currie piece inside, gave it a few whacks with a hammer, and it was then ready to weld. The finished mount is very solid. I may still put a couple gussets on there down the road for even more strength, but is probably overkill. The following pics show the end product, and I finished her off with the wire wheel and a fresh paint job. In the one pic, you can see the empty housing bore where the other jj goes.
Edit: sorry if the pics are xlarge & upside down -- not sure what happened there.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #2 of 7 Old 08-18-2010, 09:35 PM
SplitNail
Looks good. I wanna add johny joints soon too.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #3 of 7 Old 08-19-2010, 03:10 PM
wj4play
nice
wj4play is offline
post #4 of 7 Old 08-22-2010, 10:03 PM
BLACKzj52
just saw this. im thinking about getting this kit. have you got a chance go drive around with them installed?
how do you like it?
BLACKzj52 is offline
post #5 of 7 Old 08-23-2010, 10:36 AM
tsconver
2003 WJ
I think I am going Claytons in January and will be doing this mod as well, I already have a johnny inthe diff side for my IRO three link.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #6 of 7 Old 08-23-2010, 06:13 PM Thread Starter
skain8
skain8's Avatar
how do you like it?
Yeah, it's been in for about a week now. Could be my imagination, but the front end feels solid. I was slightly concerned about more road "noise". The only rubber bushings I have left are the front lowers and I can't tell any difference. After reading a bunch about rubber vs solid joints on MC and Pirate the more I'm convinced that's web wheeler lore.
skain8 is offline
post #7 of 7 Old 08-24-2010, 03:08 PM
BLACKzj52
likewise. ill be putting my clayton knock off kit on here soon
good news glad to hear. think i will be doing this mod then
did you weld any of the currie mount to the axle itself? or just to the old uca bracket?
rear upper control arm/ball joint almostfinished WJ Grand Cherokee Forum 14 02-07-2012 01:53 PM
Who replaced top axle bushing with johnny joint? crashcraddock WJ Grand Cherokee Forum 10 10-27-2011 08:58 PM
upper control arm bushing again arsonist_bob WJ Grand Cherokee Forum 6 11-23-2010 02:46 PM
Rear Upper Ball Joint flyboy14295 WJ Grand Cherokee Forum 33 07-26-2010 11:33 AM
03wj ball joint questions adjustable/deg/upper or lower ronsaun WJ Grand Cherokee Forum 0 05-18-2010 01:09 PM
