JKS track bar on wj - JeepForum.com
post #1 of 7 Old 03-15-2010, 04:10 PM Thread Starter
masonater84
JKS track bar on wj
I recently replaced the busings on my JKS track bar on my 2000 wj which made a huge difference in how she drives and got rid of most of the death wobble i was having. I reinstalled the bar the same as it came out but then a few days later i noticed someones pic on this forum showing it installed with the adjustable side of the bar mounted to the axle and not the body like mine is. Can someone tell me if mine was put in right? If anyone has a pic of the front end underside with the JKS installed that would be great too! Thanks
masonater84 is offline
post #2 of 7 Old 03-15-2010, 09:33 PM Thread Starter
masonater84
anyone have a thought?
post #3 of 7 Old 03-15-2010, 09:46 PM
EisBlade
EisBlade's Avatar
Wow...
The JKS has a preformed curve in it. That track bar needs to be installed with the adjustable section to the left and the curvature on the right side so that, when installed properly, it conforms with and goes around the curve of the front differential.
JT
Facebook: Harley-Davidson Touring Group
EisBlade is offline
post #4 of 7 Old 03-15-2010, 09:50 PM Thread Starter
masonater84
no need for wowing, it was just a simple question. but thanks, looks like the shop did put it in wrong afterall
post #5 of 7 Old 03-15-2010, 09:53 PM
EisBlade
EisBlade's Avatar
We all make mistakes...and it is comical when you think about it. If you plan on tooling on your own vehicle you'll have to learn to laugh at yourself too. Great medicine.
You're able to fit 265x75's on with only 2.5 inches? Did you have to trim any, or do you rub some?
edit: ohh, with uc springs. That's what, 3.5in total then?
JT
EisBlade is offline
post #6 of 7 Old 03-16-2010, 12:07 AM Thread Starter
masonater84
There was some rubbing on around the bottom of the fogs but a dremel took care of that. I really like the way the 265/75's fit and look. Yep, right about at 3.5'', i think, its been a while since the lift was put in and i measured. Ill check it out tomorrow when i switch the track bar around. The shop also broke one of the bump stop bolts off and never told me, i wish they hadnt gone out of business or id call them up and give them a piece of my mind!
post #7 of 7 Old 03-16-2010, 12:28 AM
WJChris
WJChris's Avatar
now I guess we know why.
Ill second EIS, the TB position you described is backwards, adjustable side closest to the axle.
WJChris is offline
KOR adj. track bar kwb18 ZJ Grand Cherokee Forum 10 09-13-2007 11:53 AM
wj track bar? 99grand4.0 ZJ Grand Cherokee Forum 4 09-04-2007 09:18 AM
Adj. Track Bar DTrem08 ZJ Grand Cherokee Forum 4 08-29-2007 10:52 PM
What is track loc? jeeper_creepers ZJ Grand Cherokee Forum 11 08-04-2007 07:30 PM
track bar byrdmanzoner ZJ Grand Cherokee Forum 2 07-19-2007 03:08 PM
