jk wheels and tires on wj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > jk wheels and tires on wj
Year End Clearance Sale! Save 20%Santa Kolak Announces: Kolak Exhaust 20% Off Sale!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 07-20-2014, 10:00 PM   #1
Lrw95
Wj jk wheels and tires on wj
I want to put jk wheels on my wj. I was wondering if I can do it while remain completly stock (for now). Ive read other threads on here and from what ive read, 245/70/r17 will be my best bet without trimming. A question that ran through my head is what about spacers? Could that help at all? I was wanting to put spacers on anyways. So let me know your input. Thanks.
Lrw95 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 12:45 AM   #2
losttech
losttech's Avatar
there lots of info out there on this but here is what I have on mine.
17 JK takeoffs the ones in my pic there and 245/65/17 which really is a stock height I think anything bigger then that will rub and also wont fit in the spare area.
Now sure you can run them but if you wheel it will rub for sure 2 inch spacers would do the trick but you will want new shocks eventually.
Just curious are the 245/70/17 already on the wheel or is that the size your looking to buy? if not on the wheel and you don't want to lift go to the 245/65/17 better fit for stock.
2000 Jeep grand Cherokee
I6, selectrac, dana 30 front 44a rear
Stock not lifted.
losttech is online now   Reply With Quote Quick reply to this message
Unread 07-21-2014, 12:47 AM   #3
BrokeWJ
I got the 255/75/17s and they didn't fit even close to stock.
BrokeWJ is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 08:59 AM   #4
1 Long CJ
245/65/17 (worn) , 3/4" front spacers, no wheel spacers.
Life is short. Play hard.
1979 CJ5, 1982 CJ8, 2004 WJ, 2006 LJ Rubicon
1 Long CJ is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 10:34 AM   #5
swkenobi
2003 WJ
You can go up to 245/70-17 without any rubbing and it will fit in the spare carrier. Anything bigger and you will either need a lift or start trimming the bumper.
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 10:56 AM   #6
braddf
x2. I am running that size with no problems
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 12:41 PM   #7
Miloe
Factory JK wheels/tires, no spacers, on a 2" BB rubbed for me on the inner fender when turning while backing up.
This was on pavement too. I got away with some careful, light wheeling but if you get a little more serious off road, the tires will rub.
Miloe is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 03:51 PM   #8
Lrw95
Thanks everyone. This helps me out a lot. The tires I mentioned are just what ive read that will work. I dont actually have anything on right now. Just stock wheels and tires. As wheel spacers go, whats my best bet? Like size.
Unread 07-21-2014, 03:56 PM   #9
swkenobi
2003 WJ
Why run spacers at all? It's not like you need them. I run the JK takeoffs and have with no issues at all.
Unread 07-21-2014, 05:15 PM   #10
losttech
losttech's Avatar
Man my 245/65/17 would just barely fit in the carrier and that was with a little air down also.
Does your lid sit flat and did you have to air it down?
Just curious what brand it is mine is a goodyear trailmark a all season type tread not really aggressive.
Stock not lifted.
Unread 07-25-2014, 10:30 PM   #11
Lrw95
ok one more question. i think (correct me if I'm wrong) the stock tire for those rims are the good year wranglers 255/75/R17. now I'm only kind of good with knowing tires so will these fit or not?
Unread 07-26-2014, 05:46 AM   #12
losttech
losttech's Avatar
To big without some lift those are 32's stock is 29.5 at the biggest.
Here a nice chart someone made.
Stock not lifted.
Unread 07-26-2014, 01:14 PM   #13
Lrw95
yeah i figured they wouldn't fit. looks like ill have to buy the wheels and tires separately.
Unread 08-01-2014, 10:49 AM   #14
Jwhughes3
Badger don't care!
Jwhughes3's Avatar
Thanks to whomever made the chart. Very helpful.
JW
Jwhughes3 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2014, 11:27 AM   #15
losttech
losttech's Avatar
JW
I don't remember where I first saw it but took a copy and its very useful.
good job to somebody
I am try to make a listing of the clips and fasteners that are used since that's always getting asked for.
Stock not lifted.
