JK take offs spacers still needed? - JeepForum.com
post #1 of 16 Old 09-03-2013, 09:57 AM Thread Starter
MattJeep
2003 WJ
If I used a set of Rubicon wheels from a JK, will they still be tucked in like stock WJ wheels? Spacers are needed to space them out better correct?
MattJeep is offline
post #2 of 16 Old 09-03-2013, 10:02 AM
swkenobi
2003 WJ
They'll be fine. I put a set on my WJ and have no issues. If you go to a larger tire, you may have issues. The backspace is 6" vs 6.5" for stock rims so they are moved out a little and look great.
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline
post #3 of 16 Old 09-03-2013, 10:06 AM Thread Starter
MattJeep
2003 WJ
You have pics from the front? I wanna make sure they are out enough. I don't like when the wheels are tucked in too far.
MattJeep is offline
post #4 of 16 Old 09-03-2013, 10:24 AM
swkenobi
2003 WJ
Let me get some and I'll put them up.
swkenobi is offline
post #5 of 16 Old 09-03-2013, 11:18 AM
vmo23
Have a shot here from the rear. I'll try to snag one from the front soon.
vmo23 is offline
post #6 of 16 Old 09-03-2013, 12:31 PM
swkenobi
2003 WJ
Not a great shot but you see clearly it sits perfectly.
swkenobi is offline
post #7 of 16 Old 09-03-2013, 01:33 PM Thread Starter
MattJeep
2003 WJ
Thanks so much for the pics. Would you say they stick out more or less than factory wj rims?
MattJeep is offline
post #8 of 16 Old 09-03-2013, 01:35 PM
swkenobi
2003 WJ
Hard to tell the difference, maybe half inch or less.
swkenobi is offline
post #9 of 16 Old 09-03-2013, 02:50 PM
CrazyWalnut13
I noticed that will my 2013 Rubicon wheel/tire take-offs, the right rear tire was rubbing on my tailpipe during certain flex situations. I took them off for now, getting 1.5" spacers in the next week or two.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #10 of 16 Old 09-03-2013, 03:15 PM
swkenobi
2003 WJ
Those are 255/70-17 tires right. That might be the issue, I am currently running the stock 235/65-17's and plan only to upgrade to245/70-17's in the future.
swkenobi is offline
post #11 of 16 Old 09-03-2013, 08:55 PM
multmigs
2003 WJ
i have JK rubicons with 245/70/17 tires mounted for past year and they do not rub anything and do stick out just a bit more than stock as shown above but looks way better than stock even without lift.
multmigs is offline
post #12 of 16 Old 09-03-2013, 09:42 PM
Trav1s
I am running JK Moabs with Cooper Discoverer AT3 255/65R17 without any problems. I have not noticed any problems with the difference in offset. I don't have any other pics than these:
04 Columbia Ed 4.7 HO/QTII/SSD107/UC/Bilstein 4600/RB4/Moabs/Cooper Discoverer AT3's/PML trans pan
Trav1s is offline
post #13 of 16 Old 09-03-2013, 10:58 PM
vmo23
From the front.
vmo23 is offline
post #14 of 16 Old 09-18-2013, 02:51 PM
AIRBORNE
I just put on 255/75/17 BFG M/T (Rubi take offs). I trimmed a litte of the fender well lining, but now it looks like it is maybe getting into the fog lights when backing out of my driveway. I was just curious if wheel spacers would help, or should I just go ahead and count on permanently removing the fog lights?
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #15 of 16 Old 09-18-2013, 02:53 PM
Thomahawk
2006 XK Commander
Putting your wheels further out will only require more trimming, time for baja cut.
Buildthread
Thomahawk is offline
