JK Axles into WJ FAQ/Writeup? - JeepForum.com
post #1 of 7 Old 05-01-2010, 08:02 AM Thread Starter
theksmith
2003 WJ
I've heard a fair bit about what's going to be required to get the JK axles into the WJ, but i still have a few questions... i know this has already been done by lots of people but has anyone put together a good FAQ or writeup on the full swap details? (no use re-inventing the wheel)
some specific questions i haven't seen addressed yet (i'm running the clayton 6" lift)...
- front shock mounts, control arm mounts, and coil buckets are all re-usable as-is i think?
- brake lines?
- e-brakes?
- tone ring pickups (use jk ones and splice into wj wires or put in the wj ones on the jk knuckles somehow)?
- superchips programmer or truespeed or what to get the speedo back inline with the different tone ring tooth count?
- rear i just get the clayton axle bracket kit for all new buckets, arm and shock mounts, and get the truss with the upper arm mounts?
- front bump-stops still work?
- swaybar disconnects still work?
- any other specific gotchas?
thanks in advance
theksmith is offline
post #2 of 7 Old 05-01-2010, 09:21 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Rumor has it that the coil buckets "need" to be moved in an inch or so on each side...Ken?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 7 Old 05-01-2010, 09:23 AM
GraKee99
Rapist Wit
GraKee99's Avatar
I thought you could get away with leaving the front the same but the springs will bow, the rear has to be all redone.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 7 Old 05-01-2010, 10:28 AM
FirefightinWJ
I believe you are right. I discussed this with TXWJ...he felt the front would be essentially a bolt in if you could live with the bowed springs.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #5 of 7 Old 05-01-2010, 01:09 PM
Robinton
check out ironrock off road
1999 XJ
2 inch lift
31 10.50-15 Cooper AT3
AEM CIA
Robinton is offline
post #6 of 7 Old 05-01-2010, 03:21 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Somewhere I read about having the WJ's rings fitted onto the JK axles.
And then a truspeed would be nice because you'll obviously have bigger tires.
WALTER
walter_da_jpr is offline
post #7 of 7 Old 05-01-2010, 08:23 PM
xJoshxx
2012 WK
i believe IRO does all that good stuff for you?
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
Another efan writeup w/pics HighLonesome ZJ Grand Cherokee Forum 28 02-08-2013 02:48 PM
Steering Box Writeup on WJ dmextreme77 ZJ Grand Cherokee Forum 3 03-05-2010 08:03 PM
Went to LED's. Short writeup. H3RESQ ZJ Grand Cherokee Forum 18 01-04-2007 04:18 PM
8.8 writeup/pics PumaZJ ZJ Grand Cherokee Forum 9 03-03-2006 11:02 PM
F>R Writeup Part 1 GroundClearance ZJ Grand Cherokee Forum 32 02-19-2006 05:03 PM
