Jeep wont idle after battery went dead. - JeepForum.com
post #1 of 34 Old 04-27-2012, 09:59 PM Thread Starter
rkperry1
Was putting on my long arms today and left my doors open and my battery died. went to go jump the car and it didnt want to start and stay started. finally got it stated by having the pedal down. after it would contatnly stall. would have to feather the pedal to keep it alive. got to to stay around 450 rpm idle in park which is really low??? what would cause this after a dead battery?
Something in engine bay is ticking or hissing possiblly? IAC??
2001 Grand Cherokee 4.0 Inline. 4 inch Lift with Bilsteins, 245/75/16 BFG ATs. Westin bull bar, Halos, 12" JL Audio W7
rkperry1 is offline
post #2 of 34 Old 04-27-2012, 10:09 PM
WJlover
my first guess, throttle position sensor?
my zj had a tick and a similar issue, TPS was my issue.
or maybe timing. a 240sx i had did this. started and ran fine (although like ****, but it started) and then one day the battery died, and it wouldnt start anymore. turned out my timing was off an *** ton. along with other issues but thats another story.
WJlover is offline
post #3 of 34 Old 04-27-2012, 10:12 PM
HVACNY
2013 WK
There is a vacuum line under the battery tray that breaks easily,has caused alot of problems for alot of people.Not sure if thats your problem,but its worth a look to see if you broke it.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #4 of 34 Old 04-27-2012, 11:31 PM
StrokedWJ
StrokedWJ's Avatar
If the battery was dead, it will take some time to fully recharge it. You need to drive it for a while to let the alternator charge the battery back up. Probably a good idea to get your battery tested if its more than a few years old. The WJ's can start acting real funky when the battery gets low on juice.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 34 Old 04-27-2012, 11:37 PM
the88thpianoman
2003 WJ
This IS your problem/solution:
When the battery died, your computer reset. When you jumped it, it wouldn't start right away, so you pressed the gas pedal to coax it to start. In doing so, the computer learned the incorrect throttle position for idle. To fix this, disconnect the battery for at least a half hour to reset the computer again. When you start the Jeep back up, turn it to the on position, but not start, to prime the fuel system. After sitting in the on position for three seconds, turn the key over to start and it will fire right up, and DO NOT touch the gas pedal. Let it idle for a few seconds before doing anything, and the computer will learn the correct idle parameters.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #6 of 34 Old 04-28-2012, 01:34 AM
deanlad1980
Save your time I promise you that you need a new battery that is all
Had this on 3 jeeps so talking from experience, your battery shouldn't really die from leaving door open unless is ****ed in the first place.
I'm not trying to be a know all but don't waste your time doing anything else just change the battery.
deanlad1980 is offline
post #7 of 34 Old 04-28-2012, 02:02 AM
pinky2252s
I would at least try this first^ since its free.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #8 of 34 Old 04-28-2012, 06:23 AM Thread Starter
rkperry1
the car doors and music was going from 7 30 am till 11 at night
rkperry1 is offline
post #9 of 34 Old 04-28-2012, 06:23 AM Thread Starter
rkperry1
gonna try this first
rkperry1 is offline
post #10 of 34 Old 04-28-2012, 06:49 AM Thread Starter
rkperry1
started it up this morning at it was at 900 for a cold start.. problem fixed for now and i didnt do anything
rkperry1 is offline
post #11 of 34 Old 04-28-2012, 09:02 AM
HVACNY
2013 WK
Not for nothing but why didnt you say that in the first place,you made it seem that you just left your door open for a few,then went to jump it.Had you said that that you drained the s**t out of it,then people would have said just jump it or get a new battery,instead of insuating that there was something deeper to the issue.Whats the problem.
HVACNY is offline
post #12 of 34 Old 04-28-2012, 12:27 PM
gtg413i
2003 WJ
X2 that the system needs to relearn. I had exact same problem after drained battery. Mine never would run for 3 seconds before shutting off, so you may need to drive with two feet for about 15 minutes. As you brake and the jeep starts to stall, give it some gas. Keep the other foot on the brake. Do this for about 10 minutes, then get it up to highway speeds, then you should be fine after that. Be careful driving with two feet at first.
Brian's Black Betty Build:
gtg413i is offline
post #13 of 34 Old 04-28-2012, 03:58 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Personal Experiences:
1. When I leave my doors open, after 10-15 min the interior lights will go off by themselves (with the doors still open) Maybe you were opening and closing. The Music will kill it though!
2. With a dead battery the WJ does not like to work, at all. When mine was dead, I ended up being a new battery and it took the computer a few seconds to "re-learn" the idle settings. It bogged then came back up and the leveled out.
3. When I had initially tried to recharge my "dead" battery. I also hit the gas to keep it from dying, around 1500 rpms. While I had just started it. Then when I let off, it went back down to the correct idle. I personally did not have an issue with improper idle when I just reset the battery, and cranked it for the first time.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #14 of 34 Old 04-30-2012, 08:00 AM
jerrybud
I'm having the same issue with my 2001 GC -- won't idle for anything! Tried disconnecting the battery and resetting the computer, and it idled fine in the driveway for 30 minutes or so. When I restarted it later it was back to idling at 450 or so, then it would just stall out. It drives fine down the road, but when I come to a stop I have to "drive with two feet". Replaced the TPS about a month ago (due to another issue), and I've never had issues with the battery, but it is almost 5 years old... should I replace it, or is it something else?
jerrybud is offline
post #15 of 34 Old 04-30-2012, 11:35 AM
the88thpianoman
2003 WJ
Have the battery checked; it could likely be your problem. If your TPS wasn't from the dealership, that could also be a problem. Your throttle body probably also needs cleaning and you may need a new idle air control motor.
URGENT help- dead battery? chrisstromberg WJ Grand Cherokee Forum 7 08-12-2011 10:33 PM
p0051 causing dead battery??? rcking323 WJ Grand Cherokee Forum 1 07-05-2011 11:10 AM
battery dead! joshjones84 WJ Grand Cherokee Forum 7 03-28-2011 10:09 AM
Jeep Wont Start, brand New Battery bnlhead WJ Grand Cherokee Forum 1 09-12-2010 01:16 PM
Dead battery: DRB3 cannot talk with modules facethewolf WJ Grand Cherokee Forum 6 07-24-2010 11:35 PM
