Jeep Won't Start - Page 2 - JeepForum.com
post #16 of 24 Old 11-28-2013, 06:04 PM
new2site
Originally Posted by FFuries View Post
Cables have been cleaned, checked, all connections cleaned and check, relay tested.
Yeah...but you didn't cut either of the terminals off to see if your cables are caked with corrosion inside...correct?..see my earlier post...
new2site is offline
post #17 of 24 Old 11-28-2013, 09:51 PM Thread Starter
FFuries
Actually cables were cut about three months ago, with new connectors put on the ends. This has been an on-going issue for a little bit. Last week cables cut again, using same connectors, when the starter and battery were removed and tested.
Yes wires on cables are dullish in color but not showing signs of corrosion that I can see, that is not to say that there isn't corrosion futher down on the wires, that I cannot see.
Mike in Florida
USAF Retired
Stock 1996 Jeep ZJ Limited
4.0 L
Stock 2000 Jeep WJ Laredo
4.7, Loaded W/ Every Option Available
FFuries is offline
post #18 of 24 Old 11-29-2013, 12:10 AM
nolimitssjca
Given that the Battery and Starter have tested ok that leaves just the connection between them. I would suggest taking the second battery and connecting a new cable to the starter as a test. The should rule in or out the existing wire.
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline
post #19 of 24 Old 11-29-2013, 01:16 AM
veiri86
2003 WJ
I suspect the crank position sensor if you are sure that both starter and battery are good. Try to pull the code using the key trick and report back which codes you get.
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #20 of 24 Old 11-29-2013, 07:49 PM Thread Starter
FFuries
Was out shopping all day with the family, just tried the key test to pull the codes. No stored codes, flashes "Done" as soon as the cycle is finished.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #21 of 24 Old 11-29-2013, 07:51 PM Thread Starter
FFuries
Still need to give this a try.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #22 of 24 Old 12-06-2013, 10:56 AM
n9ljx
Any Update?
My 2004 4.0l did this 1.5 months ago. Turn key, single click, then nothing. After 20 minutes of looking and scratching my head and convincing my mother-in-law that it indeed had plenty of gas it started. 2 weeks ago, same thing. This time I whacked the starter from the top with a long breaker bar and it started. Today, same thing but no amount of pounding will get it to go. HOWEVER - when it failed today it did begin to turn over and then went to the one click. I think I have a 'bad spot' in the starter (old blazer used to do the same thing) but if there is something easier to try than starter replacement I am all for it. Today it was colder than it has been for a few weeks, if that makes a difference.
--sas
2004 WJ Special Edition
Still stock - but working on it....
n9ljx is offline
post #23 of 24 Old 12-12-2013, 09:52 PM
leaf001
I'm having the exact same issue. Put in a brand new battery and the intermittent problem still exists.
It's been happening on and off for about a year. It's been pretty chilly out, not sure if that is a contributing factor or not.
leaf001 is offline
post #24 of 24 Old 12-13-2013, 03:23 AM
86cj74.2L
86cj74.2L's Avatar
The contacts in the starter need replaced. They have a life cycle. After so many starts he contacts are worn enough they won't touch properly.
So, you have two options. Replace the contacts. They run around 20 or less dollars. Or get another starter.
86cj74.2L is offline
