Jeep Won't Start - JeepForum.com
post #1 of 24 Old 11-23-2013, 11:35 AM Thread Starter
FFuries
Jeep Won't Start
2000 Jeep WJ, when trying to start it, single click and that's it. Lights all work, along with the CD/radio when trying to start it. No sounds of it wanting to start in anyway.
Had battery tested: Tested good
Had starter tested: Tested good
Put it all back together started three times and now won't start again. Thinking starter but wanting opinions.
Mike in Florida
USAF Retired
Stock 1996 Jeep ZJ Limited
4.0 L
Stock 2000 Jeep WJ Laredo
4.7, Loaded W/ Every Option Available
FFuries is offline
post #2 of 24 Old 11-23-2013, 12:08 PM
bradywgn71
bradywgn71's Avatar
Might be a bad relay (#30). Try swapping it with another one in the underhood junction box.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 24 Old 11-23-2013, 12:52 PM Thread Starter
FFuries
Just tried the relay suggestion with no luck. Same symptoms as before.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #4 of 24 Old 11-23-2013, 01:12 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
You said you had the battery tested, was it removed from the jeep and did you make sure the terminals were clean? This is a classic indication of dirty terminals/bad grounds. It takes a lot of amperage to turn the starter but very little to run the lights/radio ECT.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 24 Old 11-23-2013, 01:24 PM Thread Starter
FFuries
Battery removed for testing, terminals are extremely clean (IE no fuzz growing and no white build-up anywhere). Maybe looking at bad battery cables?
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #6 of 24 Old 11-23-2013, 04:08 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Could be cables, but check the ground cable where it goes to the frame/motor for cleanliness. Also take off the Positive cable and take some sand paper to the battery post and the inside of the cable connector. Just because there is no fuzz/white stuff doesn't mean they are clean. My tractor battery cable looks clean, but about every 6 months I have to take the Positive terminal off and clean it because it won't start.
Lifetime member #13
post #7 of 24 Old 11-26-2013, 06:24 PM Thread Starter
FFuries
Sand paper taken to battery terminals, and battery cable ends, with the same outcome.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #8 of 24 Old 11-26-2013, 08:40 PM
new2site
Me and another WJ owner had battery cables that were CAKED INSIDE with corrosion the last couple inches leading up to the terminals (it's stranded wiring inside) - You might want to get some replacement terminal ends and jump into cutting your terminals off to see if you have the same problem...have some baking soda and wire brush ready too for cleaning.
As you know our WJ's have dual cables to each terminal so you'll want some terminals like these:
http://www.ebay.com/itm/Earthquake-S...item232fdaa852
Might have to jerry-rig something with standard terminals until these show up in mail.
new2site is offline
post #9 of 24 Old 11-26-2013, 09:07 PM
rdkendrick
2003 WJ
Originally Posted by FFuries View Post
2000 Jeep WJ, when trying to start it, single click and that's it. Lights all work, along with the CD/radio when trying to start it. No sounds of it wanting to start in anyway. Had battery tested: Tested good Had starter tested: Tested good Put it all back together started three times and now won't start again. Thinking starter but wanting opinions.
Did they load test it? Many threads on here start with "had battery tested and it was good" then later turned out to be a bad battery. These WJ's are very power sensitive and need all the power they can get when starting. Clean terminals, clean posts.
Sent from my iPad using my fingers
rdkendrick is offline
post #10 of 24 Old 11-27-2013, 05:56 AM
marcall
single click sounds like a starter. Have someone turn it to crank and hold it while you hit the starter body with a hammer and see if it starts.
marcall is offline
post #11 of 24 Old 11-27-2013, 08:56 AM
LarryDallas
Having this same issue the past few days. Need to chase down the problem. Let us know if you find the culprit. I am not getting the 'click' sound, so I really don't think it is a bad starter. It either fires right up or get all lights but no crank at all, which makes me think it is a power issue. I got a new battery six months ago (old one had lasted like 7+ years) so I doubt that is the culprit. I will check my ground straps and maybe replace the battery terminals first.
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline
post #12 of 24 Old 11-28-2013, 09:43 AM
new2site
update?
new2site is offline
post #13 of 24 Old 11-28-2013, 04:09 PM Thread Starter
FFuries
Battery has been load tested and passed. Swapped the batteries around in both Jeeps with the same result in the WJ still. IE Both batteries work in the ZJ (Both have passed load testing) but will not work in the WJ.
Cables have been cleaned, checked, all connections cleaned and check, relay tested.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
post #14 of 24 Old 11-28-2013, 05:31 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Will it start if you jump it? If so I would probably change the cables at this point.
Lifetime member #13
post #15 of 24 Old 11-28-2013, 05:35 PM Thread Starter
FFuries
Did not start the other day when trying to jump start it.
Mike in Florida
USAF Retired
4.0 L
FFuries is offline
