Jeep WJ transmission fluid temperature - JeepForum.com
post #1 of 18 Old 11-08-2013, 09:26 PM Thread Starter
Relax_Jimmy24
My transmission fluid temperature is at 225. I switched out the filters with brand-new Mopar ones and brand-new ATF 4 fluid. Along with all sensors and solenoid. Any idea why the temperature would be so high?
Relax_Jimmy24 is offline
post #2 of 18 Old 11-08-2013, 11:01 PM Thread Starter
Relax_Jimmy24
Also i put 10 quarts of ATF4 and when i check the dip stick its on the 2nd hole of cold. I am afraid to add more as they state for a filter change it should be 6.5 quarts.
post #3 of 18 Old 11-09-2013, 12:04 PM
dlundblad
2003 WJ
Are you checking it while the transmission is hot or cold? Drive it around and let the fluid come to temp then check it. Should be somewhere between the 2 hot markers. Not too sure on what the actual temperature should be though.
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
post #4 of 18 Old 11-09-2013, 12:17 PM Thread Starter
Relax_Jimmy24
Ok i took it to the dealer and they set the fluid level were it should be. It was a quart low.
But the temp is still at 225F. Is this normal???
post #5 of 18 Old 11-09-2013, 12:24 PM
dlundblad
2003 WJ
I would still check it when the fluid is at operating temperature. Do you have a transmission temperature gauge?
03 WJ Laredo 4.Sl0w
post #6 of 18 Old 11-09-2013, 01:04 PM Thread Starter
Relax_Jimmy24
I checked it right now and its right were it should be at operating temperature. I am using the super chip tuner to see the transmission temp. Everything works fine. Shifts great. Just that temperature problem, which i do not know if its normal.
post #7 of 18 Old 11-09-2013, 05:41 PM
rm2001wj
rm2001wj's Avatar
The transmission fluid cooler is in a portion of the engine coolant radiator. It seems to me that the ATF temp would be close to or a little higher than the engine coolant temp. That 225 is probably normal.
rm2001wj is offline
post #8 of 18 Old 11-09-2013, 08:43 PM Thread Starter
Relax_Jimmy24
Alright. Since all I seen was that higher than 200 is bad for the transmission I was worried and thought something was wrong.
post #9 of 18 Old 11-10-2013, 07:53 PM
Trav1s
That is about the temp that I would have expected. I have been threatening to install a trans temp gauge in my PML pan and your thread has inspired me to look into it more.
04 Columbia Ed 4.7 HO/QTII/SSD107/UC/Bilstein 4600/RB4/Moabs/Cooper Discoverer AT3's/PML trans pan
Trav1s is offline
post #10 of 18 Old 11-10-2013, 08:31 PM
Jeepers21
I wouldn't mind learning more about your tranny temp gauge set up?
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
Jeepers21 is offline
post #11 of 18 Old 11-11-2013, 05:56 AM
Trav1s
This is what I am going to use for my install:
Autometer 2640 Electronic trans temp gauge
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
I am going to use this mount and put it in the cubby hole in the dash below the heater/ac controls
I am going to use these to angle it so it is easier to see from the driver's seat
Here is the PML pan that is tapped for the gauge.
Trav1s is offline
post #12 of 18 Old 11-11-2013, 08:45 AM
Rough Country
Vendor
Rough Country's Avatar
I was having high temps on mine when I would pull my boat (yes i turned o/d off) so I installed a trans cooler with a fan and now my temp never gets over 180.
Here is the Hayden fan setup
I am pulling a 19.5ft boat with no issues now!
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
  • 731-288-6803
Rough Country is offline
post #13 of 18 Old 11-11-2013, 09:53 AM
Trav1s
[QUOTE=Rough Country;17611042]I was having high temps on mine when I would pull my boat (yes i turned o/d off) so I installed a trans cooler with a fan and now my temp never gets over 180.
What do you have for a temp gauge set-up. Ryan?
Trav1s is offline
post #14 of 18 Old 11-11-2013, 10:09 AM
Rough Country
Vendor
I have the superchip traildash programmer. I was using a autometer gauge but the read the same so I took the autometer guage out.
  • 731-288-6803
post #15 of 18 Old 11-11-2013, 12:51 PM
Trav1s
Thanks Ryan!
I ordered the parts today from Amazon. I will start a thread when they are here and installed.
Trav1s is offline
