-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Jeep WJ transmission fluid temperature (http://www.jeepforum.com/forum/f310/jeep-wj-transmission-fluid-temperature-1772705/)
Relax_Jimmy24 11-08-2013 09:26 PM
My transmission fluid temperature is at 225. I switched out the filters with brand-new Mopar ones and brand-new ATF 4 fluid. Along with all sensors and solenoid. Any idea why the temperature would be so high?
Relax_Jimmy24 11-08-2013 11:01 PM
Also i put 10 quarts of ATF4 and when i check the dip stick its on the 2nd hole of cold. I am afraid to add more as they state for a filter change it should be 6.5 quarts.
dlundblad 11-09-2013 12:04 PM
Are you checking it while the transmission is hot or cold? Drive it around and let the fluid come to temp then check it. Should be somewhere between the 2 hot markers. Not too sure on what the actual temperature should be though.
Relax_Jimmy24 11-09-2013 12:17 PM
Ok i took it to the dealer and they set the fluid level were it should be. It was a quart low.
But the temp is still at 225F. Is this normal???
dlundblad 11-09-2013 12:24 PM
I would still check it when the fluid is at operating temperature. Do you have a transmission temperature gauge?
Relax_Jimmy24 11-09-2013 01:04 PM
I checked it right now and its right were it should be at operating temperature. I am using the super chip tuner to see the transmission temp. Everything works fine. Shifts great. Just that temperature problem, which i do not know if its normal.
rm2001wj 11-09-2013 05:41 PM
The transmission fluid cooler is in a portion of the engine coolant radiator. It seems to me that the ATF temp would be close to or a little higher than the engine coolant temp. That 225 is probably normal.
Relax_Jimmy24 11-09-2013 08:43 PM
Alright. Since all I seen was that higher than 200 is bad for the transmission I was worried and thought something was wrong.
Trav1s 11-10-2013 07:53 PM
That is about the temp that I would have expected. I have been threatening to install a trans temp gauge in my PML pan and your thread has inspired me to look into it more.
Jeepers21 11-10-2013 08:31 PM
I wouldn't mind learning more about your tranny temp gauge set up?
Trav1s 11-11-2013 05:56 AM
This is what I am going to use for my install:
Autometer 2640 Electronic trans temp gauge
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
http://ecx.images-amazon.com/images/I/411S6FN7N9L.jpg
I am going to use this mount and put it in the cubby hole in the dash below the heater/ac controls
http://ecx.images-amazon.com/images/I/21iXPFsW8nL.jpg
I am going to use these to angle it so it is easier to see from the driver's seat
http://ecx.images-amazon.com/images/...SL._SX342_.jpg
Here is the PML pan that is tapped for the gauge.
http://i25.photobucket.com/albums/c5...psd0c96230.jpg
Rough Country 11-11-2013 08:45 AM
I was having high temps on mine when I would pull my boat (yes i turned o/d off) so I installed a trans cooler with a fan and now my temp never gets over 180.
Here is the Hayden fan setup
http://i271.photobucket.com/albums/j...ps53fff42e.png
I am pulling a 19.5ft boat with no issues now!:2thumbsup:
http://i271.photobucket.com/albums/j...ps6e1f80b3.jpg
Trav1s 11-11-2013 09:53 AM
[QUOTE=Rough Country;17611042]I was having high temps on mine when I would pull my boat (yes i turned o/d off) so I installed a trans cooler with a fan and now my temp never gets over 180.
What do you have for a temp gauge set-up. Ryan?
Rough Country 11-11-2013 10:09 AM
I have the superchip traildash programmer. I was using a autometer gauge but the read the same so I took the autometer guage out.
Trav1s 11-11-2013 12:51 PM
Thanks Ryan!
I ordered the parts today from Amazon. I will start a thread when they are here and installed.
The time now is 04:29 AM.
