Jeep WJ 247-242HD Swap - Page 9 - JeepForum.com
 8Likes
post #121 of 802 Old 06-23-2011, 09:47 AM
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Dash lights...
I do not see this mentioned anywhere in the thread but I would imagine the dash lights are different for the different t-cases. That is to say there are no 2wd/part/full lights on a 247 equipped jeep, or 4h/4lo list on a 242 equipped jeep.
Has anyone read a post that explains how to properly rig the dash lights?
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
post #122 of 802 Old 06-23-2011, 09:53 AM
narnwv
narnwv's Avatar
No lights on a 247, only "PART-TIME" is displayed when a 242 is in either part time mode, no light for 2wd, N, or 4hi full time.
Lights are in the dash, only a short harness is needed to go from the 242 to a connector above the transmission. This was covered in one of these swap threads.....
Sent from my Atari 2600
~Aaron
narnwv is offline
post #123 of 802 Old 06-23-2011, 10:04 AM
josephmartins
Long-time Jeep Nut
Hmmm must be different in the WJ. In my 242 equipped XJ there is a light for part (amber letters) and for full time (green letters). I will try searching the other swap threads...thanks.
Kind regards,
Joe Martins
Milford, NH
post #124 of 802 Old 08-21-2011, 11:32 AM
yrkoverland
FWIW I think that the 242HD was also available on the 2001's.
I just got my 2001 242 tcase and it is indeed an HD model.
2000 WJ- 4.7L HO swap, 247, 4" tera-flex lift, 32's, KOR Rock Rails, IRO Skid, etc...
2007 VW Touareg V10 TDI gobs of torque!
2004 Audi A8L Luxobarge
2008 Z06 cammed and slammed
yrkoverland is offline
post #125 of 802 Old 10-09-2011, 11:43 AM
Biggie862005
Ok so I want to clarify this, as this thread has confused me a bit. I have a 2000 V8 247, and want to swap to the 242HD. ALL Im going to need is the 242HD and the rear DS? EVERYTHING else is going to bolt right up? Front drive shaft, shifter cable etc. Will I have to switch things from the 247 to the 242 for things to work? What is all the talk of switching yokes? Can someone explain that?? I suspect my 247 is on the way out and am going to eventually do this swap, and just want everything clarified before I do so.
Biggie862005 is offline
post #126 of 802 Old 10-09-2011, 11:50 AM
4xrpm4x
You have to switch yolks if you have a cv style front drive shaft.
4xrpm4x is offline
post #127 of 802 Old 10-09-2011, 11:53 AM
4xrpm4x
I believe the 242 came with only the u joint yoke. And 247 came with either a cv yoke or a u joint yoke
4xrpm4x is offline
post #128 of 802 Old 10-09-2011, 11:59 AM
4xrpm4x
The u joint yoke ( double cardon style front drive shaft) is the more desirable front shaft to use. Especially if you jeep is lifted
4xrpm4x is offline
post #129 of 802 Old 10-09-2011, 02:42 PM
Biggie862005
Ok so I would either have to swap the yoke on the front DS or swap the front DS to the ujoint style? The rear would be plug and play i assume along with everything else? Any compatability issues with the shifter or shifter cable?
post #130 of 802 Old 10-09-2011, 03:11 PM
4xrpm4x
First post
"If you have a 1999-2001 WJ, you might have a CV joint at the transfer case instead of a u-joint. In this case you will need to also find a donor shaft out of a 02+ V8 Grand Cherokee, or swap your old output to the new transfer case. The u-joint setup is much better and highly recommended however."
I don't know what you have, as far as tcase yokes and drive shafts. So can't comment on what you need to swap if any thing.
Also in the first post it has a photo of the shift cable bracket and instructions on what you need to do with it.
Move it from the top to the bottom hole on the bracket.
4xrpm4x is offline
post #131 of 802 Old 10-09-2011, 03:30 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
4xshaft.com has a lot of info on types of driveshafts.
This is wrong. The 242 could have came with a CV driveshaft
btw, instead of posting 3 times in a row, you can edit and add to your first post
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #132 of 802 Old 10-09-2011, 03:32 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
What is your build date? Obviously you have a late 2001.
post #133 of 802 Old 10-09-2011, 03:40 PM
Biggie862005
Yeah I read that, it was just a little confusing. That particular exerpt is not specific at all, it doesnt say if its talking about the rear or the front driveshaft. As for my WJ, the front DS has no u joints from what I can see, but the rear does. So as I understand it, I will obviously need the rear DS and either get the front from the same vehicle or swap over the part that connects my DS to the new tcase?
post #134 of 802 Old 10-09-2011, 03:45 PM
4xrpm4x
Thanks for the info, thats why i said "i believe". Cant edit from my phone. Or I haven't figured it out yet
4xrpm4x is offline
post #135 of 802 Old 11-15-2011, 09:52 PM
rockcrawlernut
Great write up. I can't wait to do this swap!
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 05:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 12:10 PM
just finished 247 to 242HD swap, now having shifting problems kmd1776 ZJ Grand Cherokee Forum 5 07-25-2009 04:21 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 01:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 02:18 PM
