Jeep WJ 247-242HD Swap - Page 5 - JeepForum.com
 9Likes
post #61 of 802 Old 07-14-2010, 12:09 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Originally Posted by uticaGC View Post
Nierace,
In my 99 QD I can only shift into 4low when the shifter lever is in Neutral. I'm assuming the BCM locks out the TC shifter from moving if I'm not in Neutral. What happens once the swap is done. Do you have shift on the fly capability or not?
There is nothing electronic stopping it from shifting. It is just really hard to drop it into 4-low while the main shaft has pressure on it. The proper way to shift into 4-low regardless of what transfer case you have is to slow down to about 5-7 mph (NOT STOPPED) shift the tranny into neutral, shift the transfer case into 4-low, then shift the tranny back into drive. With the 242, you can shift on the fly into all modes except 4-low (you should use the procedure above for 4-low)
~James
ezflip is offline
post #62 of 802 Old 07-14-2010, 12:39 PM
uticaGC
I am aware of proper shifting techniques. I've had a few command-tracs and a few selec-tracs. I just never owned a QD or QT2 (247) transfer case. I'm trying to deduce whether or not the 242hd swap is as cut and dry as the internet is telling me. I've done enough mechanic work to know that nothing is as easy as it looks/sounds from a description.
I also would like to know what exactly is involved with swapping the front output on the TC so I can keep my CV joint.
uticaGC is offline
post #63 of 802 Old 07-14-2010, 12:44 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
You must be at stock ride height? There really is no other reason to keep the CV style shaft. Either way, it is as simple as IIRC a 28mm nut. Remove it (might need a puller to get it off) put the new one on and torque it down.
The TC swap really is as easy as we make it sound. Especially if you do the HD. (Its a little more involved when going to a 242j) The HD is completely "plug and play" if you will. The only other thing you may not have seen in these threads is that you must move the shifter cable to the top hole on the bracket that is attached to the transmission.
~James
ezflip is offline
post #64 of 802 Old 07-14-2010, 12:50 PM
uticaGC
OK. I was under the Jeep at lunch at my Uncles shop and I'm starting to believe that it is plug and play. Does the 99 Grand Cherokee have the two hole shifter cable bracket or do I need to find a donor for it? I didn't look when I was under it.
A local yard has a 2002 242hd with 39000 miles on it that I can get for 525. I think I may buy it and just hang on to it until I find a day to swap it.
Yes I'm keeping the stock ride height.
uticaGC is offline
post #65 of 802 Old 07-14-2010, 12:56 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Im not sure what the specifications were for what jeeps came with the two hole bracket and which ones did not. I have an 02 laredo 4.7 and I had the right bracket. But I have seen another 02 laredo 4.7 that didnt have the right bracket. Just get down and look before you pick up the case. If you need the new bracket, just let the junkyard know and they should be able to pull it from the donor of the case. I cant imagine them even charging you for it since you are already dropping $600. If they do, should only be a few $.
~James
ezflip is offline
post #66 of 802 Old 07-15-2010, 09:33 AM
10achik
I ate what?
10achik's Avatar
I had to drill the second hole, it was a PITA, but I got it done on a friends drill press. I couldn't find the bracket at a local yard and so I made do.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #67 of 802 Old 11-23-2010, 09:23 AM
jclaudii
Has anyone ever plugged up the 4x4 light to the selector switch on the 242? The reason I ask is I have the harness for my 242 PLUS when I pulled the transmission on my rig with the 247, I noticed a wire that had a dummy plug in the end dangling off the harness going to the transmission...Could it be as simple as just hooking that rear piece of the harness up to the 242? I keep meaning to do it, but I have been fighting other demons with the Jeep. Just seeing if that is it or if it is CAN bus voodoo stuff that takes PCM programming?
jclaudii is offline
post #68 of 802 Old 11-23-2010, 09:37 AM
narnwv
narnwv's Avatar
It would be that simple, but all you get is a light on the dash that says "PART TIME" when you're in 4hi part time or 4 low.
~Aaron
narnwv is offline
post #69 of 802 Old 11-23-2010, 12:56 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Yea, you just plug it in and it works
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #70 of 802 Old 12-21-2010, 08:53 PM
Chaddy17
I just completed this swap with my 2000 WJ. I picked up a 242HD and rear DS from a 2003 WJ. I also grabbed the shifter assembly from the 2003.
Why do all the instructions I've seen on this swap never mention removing the cross member where it attaches to the Transmission? I placed a 8"x8" piece of 3/4" plywood betweem the Transmission pan and floor jack to support everything and removed the cross member bolts and the Transmission mount (4 bolts). I was then able to lower eveything enough to access the upper bolts and easily remve the lower bolts.Took me less then ten minutes to remove all 6 bolts from the transfer case.
Just made me wonder why nobody else mentioned doing this considering how hard it is to access the bolts with the mount in place.
Chaddy17 is offline
post #71 of 802 Old 12-21-2010, 09:02 PM
narnwv
narnwv's Avatar
I don't know where, but I read that as I did that when i did my swap, and I was still a Jeep newb.
~Aaron
narnwv is offline
post #72 of 802 Old 12-22-2010, 04:57 AM
Chaddy17
Yeah, I'm pretty much a newb also when it comes to these Jeeps. I bought it last September for my 17 yr. old Son to be his DD.
I think the NV247 had failed before I bought it, didn't know it until our first big snow.
Been planning to do the swap since then. I finally got around to looking for the parts last week, seems to be quite a few 242HD's showing up in the junk yards now.
The only thing I didn't do was change the front CV style DS, I just swapped the output from my 247 onto the 242.
My 247 didn't have the top bolt on the TC installed, I'm pretty sure it came from the Factory that way
Chaddy17 is offline
post #73 of 802 Old 12-23-2010, 08:17 PM
BradMB2004
Just got done with my swap, here's my offerings....
- 9/16" stubby 12pt box/open end wrench is a MUST for the top two nuts
- stated earlier is to drop the crossmember 2-3" to make access to the top 2 nuts easier..... after you drop it down 2-3" go ahead and remove the cross member and tranny mount from transmission. Makes getting to the two bottom bolts MUCH easier and give you more overall room to work. Also saves time cussing and throwing wrenches.
- takes just under 2qts of ATF+4 to fill the t-case, uses a 10mm hex for fill and drain plugs.
- jumper harness to adapt the 242's indicator switch to the vehicle's harness is #56041438AA and was about $28.00
- The seal for the tranny output extension housing on the 5-45RFE is National Seal #710928 and was $14 at Advance Auto Parts
- The tailshaft slip yoke seal for the NP242HD is only available through dealership and is #05019026AA is is about $45.00!!!
- Front DS yoke swapped directly over with 1-1/8" socket, torque to 90-130ft-lbs
- You may need a T-30 torx for u-joint strap bolts on front axle.
- crossmember to frame bolts 50ft-lbs, tranny mount to tranny 35ft-lbs, crossmember to tranny mount 35ft-lbs.
still waiting on my DS to get here i bought on ebay, i could not find one within 100 miles of metro atlanta
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline
post #74 of 802 Old 12-23-2010, 09:41 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Originally Posted by ezflip View Post
Also, to someones comment much earlier in the thread about the difference between the 242HD and the 242j, someone else commented that the HD was meant to handle the 4.7 and the 242j could grenade if it were used with a 4.7. That is simply not true. Everything about the two cases is identical except for the input shaft on the HD is slightly longer to accommodate the 5/45rfe transmission output shaft and the HD has an internal slip yoke (simply has a tail cone covering the rear output shaft) as apposed to the external slip yoke (uses a rubber boot to cover the output shaft) on the 242j. There are zero strength differences between the two cases. The internals of both cases are identical.
I'm no expert; you certainly have more experience with the 242 than I...but WJJeeps.com states: Maximum Capacity Torque: 1486 lb.-ft. (LD); 2028 lbs.-ft. (HD) for the 242. Do you have any references that can refute or confirm their (or your) claims of equal strength? I'm not trying to be argumentative, just confused/curious.
~Richard
billzcat1 is offline
post #75 of 802 Old 12-23-2010, 10:57 PM
ljhopp
The Hd has a thicker chain.
ljhopp is offline
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 05:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 12:10 PM
just finished 247 to 242HD swap, now having shifting problems kmd1776 ZJ Grand Cherokee Forum 5 07-25-2009 04:21 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 01:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 02:18 PM
