Jeep WJ 247-242HD Swap - Page 40 - JeepForum.com
 6Likes
post #586 of 776 Old 07-08-2014, 08:57 PM
Kalel
2015 JK Wrangler
The 242HD is stronger than the 231. The standard 242 is not as strong as the 231. wjjeeps.com has the specs.
2015 Jeep Wrangler Unlimited Rubicon
Kalel is offline
post #587 of 776 Old 08-24-2014, 08:25 PM
platinum5.9
2003 WJ
I need some help guys. I just put my 242j into my 03 v8 grand and everything went well and bolted right up except for the linkage. I replaced the shifter bezel, moved the linkage down to the lower hole in the bracket just as all the write ups say. After all is said and done the shift bezel and linkage do not line up. Please help!
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #588 of 776 Old 08-25-2014, 09:39 AM
cyber-junkie
There is an adjustment at the shift assembly that may need adjusting to make the shifter and the 242 line up.
cyber-junkie is offline
post #589 of 776 Old 08-26-2014, 12:09 PM
mehammered
Did you change the linkage arm on the TC or swap it?
99 WJ/rock krawler / 6.5 Long Arm / NP 242 / still working on build
mehammered is offline
post #590 of 776 Old 08-26-2014, 04:35 PM
platinum5.9
2003 WJ
I did not change the linkage arm no.
post #591 of 776 Old 08-29-2014, 09:28 AM
vettedude
Did the 242 replacement a couple of months ago. I was testing it last night and I find the motor revs higher in full time 4. At 60 mph, in 2 wheel it revs at 1600, in 4 full time it revs at 2000. Is this normal? 2004 grand overland, V8HO, 242. 265/65/17.
2004 WJ Overland, 242 TC
IRO 3'' lift w/ track bar
Fawkes recovery
General Grabber AT2 265/65/17
vettedude is offline
post #592 of 776 Old 09-14-2014, 04:17 AM
fiveseven15
in quadradrive/full time 4wd its around 2000, but at 70mph.. (with the 545rfe trans software) would make sense since it now has to drive twice as many wheels as 2wd.. but thats just a guess
fiveseven15 is offline
post #593 of 776 Old 10-22-2014, 08:42 PM
guttafixit
Hello, I have a 2000 G.C. Laredo 4.7 L engine Quadra Drive. I bought my 242u tc today with the rear drive shaft. The question I have is my front drive shaft. What I have read is I probable have the CV front drive shaft. How do I make it into having u joints? Or is it just my rear drive shaft is supposed to be u joints? I have u joints on the rear drive shaft now. But I know that will not be going back in after I change the tc. Any help would be appreciated.
Thanks, Dan
guttafixit is offline
post #594 of 776 Old 10-22-2014, 08:49 PM
WJ_allday04
a front driveshaft from a 2004 v8 wj is a double cardan which is u joints will work so if you could get your hands on one from a doner then your golden. or you can get a custom one but a stock one will be the cheapest.
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #595 of 776 Old 10-24-2014, 08:17 AM
guttafixit
Can I use my front drive shaft for now? And then find a drive shaft with u joints in it later? In the orignal post I thought he used his orignal front drive shaft. I was just wondering? The jeep is stock.
Thanks
post #596 of 776 Old 12-07-2014, 12:49 PM
platinum5.9
2003 WJ
Finally got my 242hd put in. There was a small adjustment to be made on the cable. I also had a zj front driveshaft rebuilt as it was a little longer than the wj one and bolted right up. I also installed the IRO 242HD sye and am having a custom rear shaft being made. I have a 242hd front and rear shaft and yoke to match if anyone is in need of them.
post #597 of 776 Old 12-07-2014, 01:17 PM
drwolcot
Originally Posted by platinum5.9 View Post
Finally got my 242hd put in. There was a small adjustment to be made on the cable. I also had a zj front driveshaft rebuilt as it was a little longer than the wj one and bolted right up. I also installed the IRO 242HD sye and am having a custom rear shaft being made. I have a 242hd front and rear shaft if anyone is in need of one or the other.
Looks good. I just installed the same HnT SYE from Iron Rock when I had the engine and trans out of the jeep. Did you pull the shaft out if the case or did you hack and tap it inside of the Jeep?
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #598 of 776 Old 12-07-2014, 01:56 PM
platinum5.9
2003 WJ
I did it while it was in the Jeep. Was actually really easy.
post #599 of 776 Old 12-07-2014, 02:17 PM
shockracer
Any vibs?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #600 of 776 Old 12-07-2014, 07:48 PM
platinum5.9
2003 WJ
Feels great without rear shaft. Still awaiting rear driveshaft.
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 06:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 01:10 PM
just finished 247 to 242HD swap, now having shifting problems kmd1776 ZJ Grand Cherokee Forum 5 07-25-2009 05:21 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 02:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 03:18 PM
