Jeep WJ 247-242HD Swap - Page 38 - JeepForum.com
 9Likes
post #556 of 802 Old 03-12-2014, 06:37 PM
gatorchin
Have a question..in the write up it says to drop the crossmember a couple of inches so you have room to work, and keep it supported with a floor jack..my question is, why not remove it entirely? Especially if you are doing this swap by yourself, and would need that floor jack to remove/lower the transfer case, then raise the 242 up in place?
00' Laredo w/4.7, 2.5/2" fat bobs coil spring lift, front 3/4" spacer, bilsteins 5100's from Kolak, rear addco w/greasable bushings, 245/16/75 treadwright wardens, 247>242 transfer case swap, all control arms replaced with aftermarket, and lots more $ into various parts
gatorchin is offline
post #557 of 802 Old 03-12-2014, 06:43 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
If you remove the crossmember entirely, there would be nothing holding up the transmission and transfer case. In fact, it is the only rear mount of the 3 motor mounts. Two up front, one rear. So, the entire motor would rotate towards the rear and will hit the firewall causing damage. You can remove the bolts completely and lower it a bit further that way, but youll need to keep the jack under it and be mindful of the motor in relation to the firewall.
~James
ezflip is offline
post #558 of 802 Old 03-12-2014, 07:03 PM
gatorchin
Makes perfect sense..so it would probably be better to leave the bolts in and drop it a couple of inches, just like the write up suggested..just trying to get all my questions answered because I'm ready to do the swap this weekend hopefully.
One more question..I have my front cv shaft removed (going to double cardan)..I have my front diff yoke installed..tomorrow I may have a couple hours to kill, although in bad weather..I was thinking this May be a good time to go ahead and install the select trac shifter assembly, since I can do all that work inside the jeep..would it be ok to go ahead and do this?? I, wanted to get al I can done before the actual case/driveshafts
post #559 of 802 Old 03-12-2014, 07:05 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yep, no problem doing that at all.
~James
ezflip is offline
post #560 of 802 Old 03-12-2014, 07:16 PM
gatorchin
Good to hear..wish there a was a write up w/pics..I found a write up but (text only..guess only one way to do it and that's tear into it
post #561 of 802 Old 03-12-2014, 07:21 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Are you swapping in a 242HD or an LD? If its an LD, this is from a ZJ, but it is exactly the same. http://kevinsoffroad.com/techarticle...-242_swap.html
If its an HD, just skip the part about swapping the input shaft
~James
ezflip is offline
post #562 of 802 Old 03-12-2014, 07:30 PM
gatorchin
Are you swapping in a 242HD or an LD? If its an LD, this is from a ZJ, but it is exactly the same. http://kevinsoffroad.com/techarticle...-242_swap.html If its an HD, just skip the part about swapping the input shaft
I'm swapping in the hd..I'll check that link out, thanks
Oh..after looking at the link, I was referring to a write up on the shifter assembly swap..it can't be that hard, but it's always good if you can find a write up w/ pics...the write up that began this thread should get me through the actual case swap
post #563 of 802 Old 03-14-2014, 12:09 PM
gatorchin
I'm in the middle of this and these transfer case nuts are giving me fits..the engineers didn't want this swap to happen without giving people fits..I have 3 of the 6 bolts off..funny thing is some of them are 14mm and some 15mm..can't wait till this is over
One was 15mm...this wj has had a en engine and tramsmission replaced so I'm thinking whoever did that work threw on the 15mm
post #564 of 802 Old 03-14-2014, 05:54 PM
gatorchin
Can someone help me with the bolt size I need that connect the front of 242 transfer case to double cardan driveshaft?
nevermind got the part number from the dealer
post #565 of 802 Old 03-15-2014, 08:19 PM
Kalel
2015 JK Wrangler
Do I have to swap in the Select Trac shifter?
2015 Jeep Wrangler Unlimited Rubicon
Kalel is offline
post #566 of 802 Old 03-16-2014, 05:30 AM
gatorchin
if you mean the whole shifter assembly, no you dont' have to..you could just put stickers or something where the shift points are, i know some guys did that..but i went ahead and changed out the whole assembly..its really easy..there is a write up on how to remove center console on wjjeeps.com
post #567 of 802 Old 03-16-2014, 07:14 AM
shockracer
You could also just change out the bezel
The transmission shifter knob is an SOB sometimes and you could damage the wires running up the handle when trying to get it off.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #568 of 802 Old 03-16-2014, 09:54 AM
doorjamm
Gcjeeping sells the bezels over in the classifieds
doorjamm is offline
post #569 of 802 Old 03-16-2014, 12:08 PM
gatorchin
yeah i was gonna try this route but broke my od wires in two on my 247 shifter knob
post #570 of 802 Old 03-22-2014, 11:30 PM
mehammered
I am in the process of doing this, there is a lot to know. Lots of mistakes that can be made. I will give all my notes.
mehammered is offline
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 05:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 12:10 PM
just finished 247 to 242HD swap, now having shifting problems kmd1776 ZJ Grand Cherokee Forum 5 07-25-2009 04:21 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 01:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 02:18 PM
