Jeep WJ 247-242HD Swap - Page 10 - JeepForum.com
 9Likes
post #136 of 802 Old 11-16-2011, 07:50 AM
ljhopp
Instead of having to switch rear drive shafts can't you take the output transaxle shaft from the 247 and put that into your 242 hd and everything should bolt right up.
ljhopp is offline
post #137 of 802 Old 11-16-2011, 09:04 AM
capthowdy575
nice I'm getting a 2000 GC with the lame QD and switching it to the sexy 242hd I cant wait this should help. also a nice write up of changing out the 4x4 shifters would be nice to I want it to look stock.
capthowdy575 is offline
post #138 of 802 Old 11-16-2011, 10:33 AM
robthebuilderer
ljhopp, the length is different...get the shaft when you get the case.
2014 WK2 EcoDiesel on 35's and Air Springs
#whiterhino IG @robthebuilderer
1998 XJ 3-link 4-link 241OR 37's ARB's
robthebuilderer is offline
post #139 of 802 Old 11-16-2011, 11:34 AM
ljhopp
ljhopp is offline
post #140 of 802 Old 11-22-2011, 01:20 PM
1STJEEP97TJ
Anyone have the part number for the little white shift lever bushing for the shift lever? Mine broke and the guy at the dealership looked at me like I was crazy....
1997 TJ 4cyl - SOLD
1999 WJ Laredo 4x4, I6, Selectrac - SOLD
2000 WJ Laredo 4.7 4x4, just rebuilt engine, 242 HD TC swap, 2" BB, tow hooks, Addco rear sway bar. Looking to find a 3" IRO lift, JK 17"s and 3.73 Quadradrive rear axle.
1STJEEP97TJ is offline
post #141 of 802 Old 11-22-2011, 01:47 PM
patrick983
here you go:
http://www.4wd.com/Transmission-and-...=116&t_pt=9534
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #142 of 802 Old 11-22-2011, 03:41 PM
jahcure
changing input shaft is not all that difficult if you dont have a proper snap ring pliers then getting the input shaft out of the case will be trouble some, also you need a #1 extractor to remove the pin that holds the shift fork to its shaft. once its back up dont try to test it with all the weels in the air, you will think its not working properly well it did not for mine anyway, also not because you put the case say in 4x4 fulltime that it will be in that mode if you dont know how to shift it it will be in 4x4 partime. after being puzzled for a while and a lot of reading best way to shift the case is . drive in straight line pop tranny in N shift case to desired mode then pop back in drive you should feel it engaging this is valid for 2wd 4x4part time and 4x4 full time only .
Neutral and 4x4low is while rolling at 3-5 mph shift to 4x4 low . if this is not right someone can chime in .
jahcure is offline
post #143 of 802 Old 11-25-2011, 02:30 PM
1STJEEP97TJ
Thanks for the reply but that's not the one I need. I bought that one thinking it would work but it doesnt. Mine is just like the OP's in his fifth picture. Its closed on one end and snaps in the shift cable. Unfortunately mine crumbled into a few pieces when I popped it off the shift lever. Anyone else? I'm going to try and copy the OP's pic...
1997 TJ 4cyl - SOLD
post #144 of 802 Old 12-05-2011, 01:02 AM
skidoorida
I have read up on a lot of swap threads. i have an '00 grand cherokee limited 4.7 w/ quadra-drive. quadra-drive isnt working. did fluid change and still not working and it works great in 4 low but not in fulltime. i have been following 242 swap threads and i am wondering if i get a tc out of a '00 4.7 w/ selctrac, will it bolt right up or will i have to do front and rear DS swap as well? inputs? i know i need u joints as it is but is it peezable to do the 242 out of a 00 v8? inputs please
skidoorida is offline
post #145 of 802 Old 12-05-2011, 06:15 AM
yrkoverland
You will need a rear driveshaft yes. If you do get a V8 242 see if they have the rear ds as well and will match up to the trans with no mods. You may also look at changing your front DS as it is probably the CV style if you want to put a lift on later. IMHO it's easier to do now since you will have everything apart.
2000 WJ- 4.7L HO swap, 247, 4" tera-flex lift, 32's, KOR Rock Rails, IRO Skid, etc...
2007 VW Touareg V10 TDI gobs of torque!
2004 Audi A8L Luxobarge
2008 Z06 cammed and slammed
yrkoverland is offline
post #146 of 802 Old 12-09-2011, 05:14 PM
skidoorida
Wj
ok. thanks. if i cant get a 242 from a v8 and i get a straight 6 one what would i need to do? i think i've got a v8 242 lined up, but still looking for a rear ds. but if all else fails what will i need to do to put in a i6 242? thank you
post #147 of 802 Old 12-09-2011, 05:21 PM
mudtrackerinc
mudtrackerinc's Avatar
You will need to take both cases apart and swap the inputs if you use a I6 case.
02WJ Rough Country 4" Long Arm,3/4 spacers added to front,265x70x17C BFG All-Terrain T/A KO 31.8x10.7,super 44 flowmaster,K&N air filter,JKS adj track bar,JKS HD tie rod,JKS HD draglink,RCX dual stabilzer,Mickey Thompson Sidebiter wheels 17x9 4.5"BS,Saguaro4x D-Ring Mounts
06tj RC 4" X-series ,RC Dual Steering Stabilizer, 32x11.50x15 BFG All-Terrain T/A KO, 15x8 Ultra Motorsports Rogue
Model:175 Wheels, K&N CAI & Filter,super 44 flowmaster
mudtrackerinc is offline
post #148 of 802 Old 12-09-2011, 06:20 PM
island hopper
island hopper's Avatar
will a 242 from a 2002 WJ fit my 1999 WJ?
island hopper is offline
post #149 of 802 Old 12-10-2011, 12:28 AM
robthebuilderer
Direct bolt-in, if you're swapping a v8 242 into a v8 rig....if you're trying to get any other combination (v8 to v6) you'll need to swap input shafts.
post #150 of 802 Old 01-13-2012, 11:43 AM
Vrrooom
Why would you want to do this swap? Seems like the QD works quite well and running in 2wd has no gas mileage benefits; so why change?
14 WK2 Diesel Limited, QT2, 32" Duratracs
09 Z06. Cam, other go fast goodies
98 XJ, JK D44s locked, armored, 37s, trail queen / sold
07 JK Rubi, 37s, bumpers, armor, mild lift, DD / sold
Vrrooom is offline
247 to 242HD swap questions Kramer H ZJ Grand Cherokee Forum 11 12-10-2013 05:54 PM
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 12:10 PM
just finished 247 to 242HD swap, now having shifting problems kmd1776 ZJ Grand Cherokee Forum 5 07-25-2009 04:21 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 01:27 PM
247 -> 242HD swap "Yoke question" UUJ1 ZJ Grand Cherokee Forum 4 04-18-2008 02:18 PM
