Jeep Rehab One WJ Jeeps Story of Rescue from Neglect - Page 4 - JeepForum.com
post #46 of 77 Old 09-28-2013, 10:28 PM Thread Starter
nolimitssjca
wsar10 thanks for the tips on wheels and tires. I love new sources.
Ravie here's a couple of pics of my 72 Coupe. A work in progress.
1:The Coupe
2: Rebuilt 302
3: Headers
4: Example of sand blasting parts
5: Powder coated rims
72MustangCoupe.JPG   302NewMotor.JPG   302Headers.JPG   72sandblast.JPG   72powder coated.JPG
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline
post #47 of 77 Old 09-29-2013, 07:14 AM
wsar10
2003 WJ
OKAY IM TIRED OF IT NOW !!
I CALL BS ON THE WHOLE WJ PROJECT UNITL WE SEE PICS !!
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #48 of 77 Old 10-03-2013, 10:27 PM Thread Starter
nolimitssjca
Rear Pinion Seal Change Made Easy - Dana 44a
First let me say two days for this job was TOOOO long. The job isn't that hard but having the right tools available is essential. Here is a short write up that hopefully saves someone time in the future.
Tools Required:
1: Degreaser
2: Wire Brush
3: 8mm socket
4: Bungee
5: Flat Head Screw Driver
6: Paint Pen
7: 34mm Socket
8: Impact Wrench
9: Seal Puller
10: Hammer
Steps:
1: Clean around the Pinion Seal (degreaser, sire brush)
2: Undo the 4 U-Joint bolts with the 8mm.
3: Hang the drive shaft to the side (this insures the shaft will align correctly during reassembly).
4: Clean all debris from around the nut and yoke saddle (wire brush, screw driver).
5: Mark Nut and Yoke position (Paint Pen - See picture below for example).
6: Remove the Pinion nut (34mm socket).
7: Separate the Yoke (flat head screwdriver will pry it out easily).
8: Remove Pinion Seal (seal remover).
Lessons Learned...
1: 34mm socket is available at auto parts stores - not tool stores.
2: Removing pinion nut is easier with a 1000 ft lb impact wrench. My 250 ft lb, useless, 400 ft lb, useless, 1000 ft lb, wrench successful.
3: After buying the new impact wrench (air tools) I learned plumbing for a 3/8" connector is different than the typical 1/4" connector. This took time to sort this out.
4: A seal removal tool is the fastest way to remove a seal. Skip the screwdriver and all those other things. Just go all in with a $10 tool.
If I had this to do again it would take me less than 1 hour.
post #49 of 77 Old 10-09-2013, 11:20 PM Thread Starter
nolimitssjca
Got the wheels and tires upgraded today. Wrapped the rims in some new Wrangler Duratrac's then plasti-dipped the wheels in flat black. I'm happy with the results.
245/75/16 - Tucks just inside the wells without rubbing.
post #50 of 77 Old 10-11-2013, 08:50 AM
KayCeeJeep
You got the 245/75's to fit at stock height? Or did I miss something?
KayCeeJeep is offline
post #51 of 77 Old 10-11-2013, 11:16 AM Thread Starter
nolimitssjca
You didn't miss anything. They fill the space completely.
post #52 of 77 Old 10-11-2013, 04:47 PM
cykaaro
I had 265's on mine which where the exact same height which had no issues with rubbing.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #53 of 77 Old 10-11-2013, 06:33 PM
Trxgedy
265 on stock ht? I have a set of 265 in the garage waiting on my BB. If I can fit them now I might as well. Theyre taking up space.
Trxgedy is offline
post #54 of 77 Old 10-11-2013, 06:39 PM
doorjamm
265 is the width, not height. So the height depends on the second and third number. Basically a 245-75-16 will not fit on stock height. Go online and look at tire size calculators. Basically anything that equates to a size larger than 29" will rub without trimming
doorjamm is offline
post #55 of 77 Old 10-11-2013, 07:07 PM
Trxgedy
The second and third number, so why wouldnt 265 75 16 fit if my stock tire is 225 75 16. if its just wider.
Trxgedy is offline
post #56 of 77 Old 10-11-2013, 08:22 PM
doorjamm
75 is a percentage of the first number. Not a direct size. So 75% of 225mm is less than 75% of 265mm. Last number is the rim size obviously. The 75 is the height of the sidewall
The 225 sidewall would be roughly 169mm
The 265 being roughly 199
169mm = 6.65in. 6.65x2+16 =29.3" tire
199mm = 7.83in. 7.83x2+16 =31.7" tire
doorjamm is offline
post #57 of 77 Old 10-11-2013, 08:32 PM
Trxgedy
Ahh ok, this is one thing ive been meaning to learn, so what would the largest tire id be able to rud do you think,
Trxgedy is offline
post #58 of 77 Old 10-11-2013, 08:55 PM
04dubjay
Someone should make a thread about that.
http://www.jeepforum.com/forum/f310/...-post-1304102/
2004 Columbia Edition WJ (I6/Selectrac) -{RC/Ironman4x4fab/JKS/KOR/Nitto/Carolina}
04dubjay is offline
post #59 of 77 Old 10-12-2013, 06:20 PM
cykaaro
I was surprised mine were 265's. Not sure what the sidewalls were though as it was a year ago. When I compared the height to the duratrac 245/75/16's though, they were exactly the same height.
cykaaro is offline
post #60 of 77 Old 10-12-2013, 08:42 PM
kc2mrg
sounds like what your doing with my 2004 BMW 325i i just got, very neglected, came into the dealer i work at not even running, guy got rid of it to me for $300, im about $1500 into parts so far, and some free used stuff laying around the garage
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
