Jeep Performance Issue I6 Engine - JeepForum.com
post #1 of 4 Old 06-12-2013, 03:00 PM Thread Starter
HarielA4
So my wife drives our Jeep to and from work all the time. She is having an issue that I havent experienced yet. When she is cruising with the RPMs in the 1500 range the RPMs will drop to zero then come back. While this happens she feels the engine lose power. Its only momentary. MPG's has been pretty constant. EVIC shows 16mpg average. Any ideas?
HarielA4 is offline
post #2 of 4 Old 06-12-2013, 05:31 PM Thread Starter
HarielA4
Did the code test by cycling the ignition of then off a few times and got a P0320 code which means there is an issue with the Crank Position Sensor. Guess I will replace that.
HarielA4 is offline
post #3 of 4 Old 06-12-2013, 05:40 PM
Ravie
Been there. Go OEM. I'm not usually the guy saying that but in this case I believe it counts.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #4 of 4 Old 06-12-2013, 05:53 PM Thread Starter
HarielA4
I usually go OEM for sensors.
HarielA4 is offline
