Jeep only starting in neutral. Hmmmm! - JeepForum.com
post #1 of 12 Old 10-22-2010, 09:39 PM Thread Starter
nitrox28
Wj Jeep only starting in neutral. Hmmmm!
My WJ threw a code the other day regarding the TCM. Now it won't start in park but it starts, runs, and drives GREAT in neutral. I don't mind keeping like this as long as I'm not damaging anything.
-2002 WJ Laredo. 4..7, selec-trac, leather and loaded. Other than a Flowmaster Super 40 series muffler, it's all stock.
-1998 Green Laredo 4.0, Rusty's 2" BB, Skyjacker 3" softride w/SS, Nitro shocks, ARB Bullbar, KC's, 180 degree t-stat, Flowmaster 40 series, no cat, no rear swaybar, 31x10.50xSwamper SSR's, Eagle rims, K&N filter, Alpine system, bunch of other crap.
nitrox28 is offline
post #2 of 12 Old 10-22-2010, 10:07 PM
PlatinumNiner
Its the neutral safety switch. You will fail inspection because of the CEL it throws and eventually it wont start at all not even in neutral. Replace it.
PlatinumNiner is offline
post #3 of 12 Old 10-22-2010, 10:46 PM Thread Starter
nitrox28
We don't have inspection. WOOT!
nitrox28 is offline
post #4 of 12 Old 10-22-2010, 10:52 PM
Skytard
Well I fixed a friends firebird that did the same thing. It ended up being that things shifted in his gear selector and neutral was really park and drive was drive 2 . Just a thought
Skytard is offline
post #5 of 12 Old 10-23-2010, 05:38 PM
PlatinumNiner
OK so dont worry about that then just worry about being stranded when it doesnt crank at all
post #6 of 12 Old 10-23-2010, 05:40 PM Thread Starter
nitrox28
I have a 2002 WJ with the 4.7 and selec-trac. Any way to tell what tranny I have? (i know it's a stupid noob question, but i've been out of the jeep game for a while now)
nitrox28 is offline
post #7 of 12 Old 01-28-2012, 10:54 AM
wranglergirl98
WJ not starting in park
Hey guys I need some help, I have recently switched from a wrangler to a grand cherokee and now it wont start in park. It is only doing it on an incline. If I park in the gargage on flat ground it starts fine. Is it still the nuetral safety switch?
wranglergirl98 is offline
post #8 of 12 Old 09-04-2014, 06:26 PM
WJ2001JEEP
I already replaced the neutral safety switch and it's still sometimes only starts in neutral....any ideas???
WJ2001JEEP is offline
post #9 of 12 Old 09-04-2014, 07:29 PM
DC99
2017 WK
I had similar issues, sometimes had to bump shifter forward to start in park. I removed the console and adjusted the shift cable, no problem since.
DC99 is offline
post #10 of 12 Old 09-04-2014, 09:01 PM
WJ2001JEEP
Adjusted the shifter cable in what way? Can you please give me some more info.
Thanks
post #11 of 12 Old 09-05-2014, 01:02 PM
DC99
2017 WK
Thanks
Can't remember all, it's been awhile but at the end of the cable in front of shifter there is I think a phillips screw loosen and adjust so it starts in neutral and park. You may have to play a little to get it right. Make sure it will not start in gear though. Hope this helps
DC99 is offline
post #12 of 12 Old 09-06-2014, 08:32 AM
WJ2001JEEP
Okay thanks I will try that today.
Jeep Idles very high (2k-2.5k RPMs) in Park and Neutral tpleiman WJ Grand Cherokee Forum 27 06-15-2016 12:27 AM
Jeep GC Starts only in Neutral RaptorPDX WJ Grand Cherokee Forum 3 07-12-2010 09:56 PM
Jeep WJ 2001 Creeps in neutral pebloy WJ Grand Cherokee Forum 0 07-10-2010 08:15 PM
WJ NV247 chatters in neutral and no 4x4 hi danielbaute WJ Grand Cherokee Forum 5 06-08-2010 08:02 AM
WJ Buzzing in Neutral nate1187 WJ Grand Cherokee Forum 16 05-15-2010 06:29 PM
