Jeep knocks on startup, then goes away. - Page 2 - JeepForum.com
post #16 of 19 Old 08-06-2011, 12:56 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I dunno, maybe since it is posted in here 2-3 times a week. Compared to 2-3 times a year someone posts with a blown-up 4.7.
~Richard
billzcat1 is offline
post #17 of 19 Old 08-06-2011, 02:27 PM
skiebuster
I would bet that its a cracked piston skirt. Mine did it for 80K miles....it was more noticeable with a fresh oil change. It would come and go, meaning it didn't do it every time on start up. When it started knocking the last time, it did it for 20 miles, then stopped, then did it all the way home from from a field trip.
Next morning I went for coffee and while heading to work, it tapped hard for 10 seconds and the vacuum went. I drove it 8 miles to my shop, parked it and found a 2006 wrangler 4.0 to replace it. My 4.0 had a hole you could place yur fist in....sat for 2 months for me to get ready to swap engines. It started up and drove it into my shop...needless to say, my dad and I were stunned!
We have replaced 3 of the 4.0 engines, all from piston skirts letting go. If its knocking, pull it and slap some really good pistons in it.
skiebuster is offline
post #18 of 19 Old 08-06-2011, 02:29 PM
skiebuster
Originally Posted by billzcat1 View Post
I'm guessing cracked piston. It's far more common in 4.0s than the 4.0 fans would have you believe.
I agree...read my post! the 99 and up WJ 4.0's have poor skirt design. I bet the factory made them thinner for several reasons...cost, faster revs, MPG and so that the dealer will replace it for a ton of money down the road. lol
post #19 of 19 Old 08-06-2011, 02:41 PM
shockracer
Drop your oil pan and have a look, not to pricey to do and you can inspect everything else.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
Slow Crank Startup?? alwaysHI WJ Grand Cherokee Forum 8 04-29-2011 07:15 AM
Rattle noise on startup but goes away after a minute or two jdebler WJ Grand Cherokee Forum 6 04-28-2011 10:55 AM
4.0 l knock on cold startup. firejeep344 WJ Grand Cherokee Forum 2 12-17-2010 08:55 PM
Low oil pressure after warm startup Canoak WJ Grand Cherokee Forum 7 10-26-2010 04:58 PM
JGC knocks when hot idling Dissenter WJ Grand Cherokee Forum 4 08-01-2010 10:24 AM
