Jeep grand cherokee keyless entry issues - JeepForum.com
post #1 of 12 Old 08-20-2012, 02:37 PM Thread Starter
mmmyello3141
Wj Jeep grand cherokee keyless entry issues
I am experiencing problems with the key-less entry system on my jeep grand Cherokee wj. The remote works just fine when the jeep is running and it will lock and unlock the doors, the problem i am having is that when the jeep is off and i try to lock or unlock the doors it will not work. any suggestions on how to fix it?
mmmyello3141 is offline
post #2 of 12 Old 08-23-2012, 08:25 PM Thread Starter
mmmyello3141
*****UPDATE*****
I found out after doing some messing around, that the problem is the range. I have to be right next to the front passenger door for the remote to work. And it does work very well at close range. If you get any more than a few feet away it wont work anymore. I still don't know how to fix this issue and would appreciate any sugggestions
2004 Jeep Grand Cherokee Freedom Edition, 4.5 in. clayton offroad long arm kit, bilstein shocks, jks adj. track bar, jks quick discos, and moog steering stabilizer, 245/70/17 cooper discoverer at3's.
post #3 of 12 Old 08-23-2012, 09:10 PM
Brandonsdad02
Replace the battery in your key fob. It's getting thus the reason for close range.
Brandonsdad02 is offline
post #4 of 12 Old 08-23-2012, 09:16 PM
Brandonsdad02
Getting weak
post #5 of 12 Old 08-23-2012, 09:27 PM Thread Starter
mmmyello3141
The batteries are brand new. That was my first thought as well
post #6 of 12 Old 08-23-2012, 10:48 PM
irzyxel
Had the same issue with mine when I first got it. New batteries and still only works from about 15 feet.
2004 Overland stock with 103,000 miles
irzyxel is offline
post #7 of 12 Old 08-23-2012, 11:06 PM
Cirruslydakota
The antenna for the rke is in the passanger door. It's only a wire so I'd pull it apart and see if maybe it broke. Either way you can extend it and increase its range.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #8 of 12 Old 08-31-2012, 09:31 PM Thread Starter
mmmyello3141
Will do, thanks for all of the suggestions
post #9 of 12 Old 08-31-2012, 09:36 PM
kc2mrg
is there anyway that you can re-locate the antenna to the dash or something, so you have equal range side to side?
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #10 of 12 Old 09-01-2012, 12:10 PM
Cirruslydakota
I guess you could by running it back through the boot to the underside of the dash. Just make sure to leave some slack or make a quick disconnect for the ineventable dash pull for heater core/mode door/evaporator replacement.
Bear - 99 WJ Laredo
post #11 of 12 Old 11-12-2012, 02:40 PM
wjw222
2005 WK
The keyless entry on my 2005 Grand Cherokee began to work intermittently and eventually stopped working all together. Put in new batteries and still nothing. As a test, I took off the back key cover, held the battery down firmly to the circuit board with my fingers, tried the buttons, and they worked! I tried putting a shim on top of the battery so it would put pressure on it when the rear cover was reinstalled and success! I tried a dime and a thin washer, both worked but the cover wouldn't snap shut securely. I cut a small circle the size of the battery out of a cereal box and that worked fine. I am guessing that a small circle cut out of thin plastic, like a deli container or a little thicker like an OJ container might be better. Maybe some material a little smaller that would fit inside the 3 little posts on the back cover that hold down the battery would work even better. I'll update this post when I see how long the cardboard lasts.
wjw222 is offline
post #12 of 12 Old 11-12-2012, 07:10 PM
dsodko
Our "New" '02 WJ only had 1 factory key and NO remote. After $160, we have a new factory remote and key. Remote works from 50 feet. I got a eBay remote I have to get programed @ Chrysler. Preowned Jeeps are a challenge. I figure in a year it will be like new. I sure is nicer than my '94 Grand. 4.0 was easy to fix and drive. Synthetics got me 20 MPG.
dsodko is offline
1999 Jeep Grand Cherokee Eletric Issues georgiatrucks WJ Grand Cherokee Forum 3 07-11-2012 12:59 PM
2001 jeep grand cherokee issues.. please help. i just bought this !! jtmizzell WJ Grand Cherokee Forum 12 10-25-2011 11:30 AM
2001 Jeep Grand Cherokee A/C issues wags22 WJ Grand Cherokee Forum 7 06-09-2011 06:47 AM
02 Jeep grand cherokee shifting issues Walte464 WJ Grand Cherokee Forum 2 05-02-2011 02:27 PM
Power door lock/unlock keyless entry issues. tuglife WJ Grand Cherokee Forum 3 09-12-2010 07:26 AM
