Jeep is going to sit for a while - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Jeep is going to sit for a while
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shippRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 07-20-2013, 09:57 PM   #1
f15ch3r
I am going to have to let the jeep sit for about 4 or 5 months. Is there anything I should do to it beforehand to ensure that it will run good when I get back to it? Also, it will be kept in a barn so I am a little worried about rats getting to it. Any suggestions to keep the rats away?
f15ch3r is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 10:16 PM   #2
LarryDallas
Add stabil and fill up the tank. Might want to hook up a battery tender. Shouldn't have to worry about tire flat spotting or any other issues, that isn't that long. I've heard dryer sheets around electrical keep rats out, but it isn't as good a deterent as moth balls. Problem is moth balls smell so bad you don't want that getting in your vehicle. I store a car about 5 months out of the year and just do stabil and overfill the tires 5 pounds, but those are soft compound. Also use a battery tender. I keep it in a garage, so there may be a few nice but not like you might get. That would really be my main concern. They love chewing wires.
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 10:19 PM   #3
billzcat1
Chicken in a Turkey Suit
2003 WJ
Definitely get a battery tender. Harbor Freight has one for like $20. If you are concerned about moisture in your area, get some of the Dri-Z-Air containers to keep moisture (and mold) down.
billzcat1 is offline   Reply With Quote Quick reply to this message
