jeep codes - JeepForum.com
post #1 of 7 Old 11-22-2013, 03:34 PM Thread Starter
BIGGREEN82
jeep codes
I have a 1999 jeep grand Cherokee limited v8 4.7, had a new motor put in, new sensors, new fuel pump assembly, new fuel lines, n it cranks but runs like ****, but only if u hold the gas or it dies, n blows out light blue to almost white smoke, I did the key trick on off, n got code ( p 0505) someone please help
BIGGREEN82 is offline
post #2 of 7 Old 11-22-2013, 04:37 PM
Thomahawk
Changed sensors? What sensor, there is quite s few,,,
Here you Go mr.
P0505 (M)
Idle Air Control Motor Circuits
Replace idle air control motor.
http://www.wjjeeps.com/faultcodes.htm
Disconect battery for atleast 15 min to reset while replaceing sensor, good luck
Buildthread
Thomahawk is offline
post #3 of 7 Old 11-22-2013, 06:43 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by Thomahawk
Changed sensors? What sensor, there is quite s few,,, Here you Go mr. P0505 (M) Idle Air Control Motor Circuits Replace idle air control motor. http://www.wjjeeps.com/faultcodes.htm Disconect battery for atleast 15 min to reset while replaceing sensor, good luck
Or check wiring....cause the engine was just replaced.
86cj74.2L is offline
post #4 of 7 Old 11-24-2013, 11:12 PM Thread Starter
BIGGREEN82
Thanks a bunch, will update if that fixes my problem
post #5 of 7 Old 11-24-2013, 11:34 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Lots of new sensors at one time for the PCM. And have you tried resetting the PCM by unplugging the battery...?
rep-tile is offline
post #6 of 7 Old 11-24-2013, 11:43 PM Thread Starter
BIGGREEN82
Yeah, took the battery out for a whole night to recharge.
post #7 of 7 Old 11-24-2013, 11:48 PM
rep-tile
rep-tile's Avatar
Then you problably have a massive intake leak or forgot to hook up the MAP sensor.
rep-tile is offline
