Jeep airbag and seatbelt light on at the same time ??? - JeepForum.com
post #1 of 10 Old 12-21-2013, 04:35 PM Thread Starter
FordExplorer
I switch instrument cluster today and now i got a air bag light and seatbelt light on all the time ... The old instrument cluster never had this problem .. Any suggest what's going on? ????????? thank
the Instrument Cluster i got now is from a 2004 Jeep Grand Cherokee 4.7
My Jeep is from 2000 4.0
Here is a video of the problem i been having
FordExplorer is offline
post #2 of 10 Old 12-21-2013, 05:35 PM
mycreativename
I very distinctly remember reading about some issue with the seatbelt light coming on when swapping a 03/04 gauge cluster into an older model. Did it start doing this right after you put the cluster in?
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 10 Old 12-21-2013, 05:39 PM
jfaulk
^^^I remember reading something about this too. Sorry I can't be more help.
jfaulk is offline
post #4 of 10 Old 12-21-2013, 05:57 PM Thread Starter
FordExplorer
Yes sir . Is there any way to turn off the air bag light off atleast?
post #5 of 10 Old 12-21-2013, 05:57 PM Thread Starter
FordExplorer
Where did you read this ?
post #6 of 10 Old 12-21-2013, 06:16 PM
mycreativename
1. Remove cluster
2. Remove lightbulb
3. Reinstall cluster
4. Enjoy darkness
Haha. In all seriousness, I believe that was what a lot of those members did because the airbag still was functioning as it should, just that the cluster could not interpret that data correctly.
By the way, this was the first result in Google after putting in "gauge cluster swap wj seatbelt light on":
http://www.jeepforum.com/forum/f310/...-swap-1244109/
post #7 of 10 Old 12-21-2013, 06:42 PM Thread Starter
FordExplorer
1. Remove cluster
2. Remove lightbulb
4. Enjoy darkness
Thank .. But I did that already there's no light bulb for the air bag , only light bulb that is on the top where the air bag is the high beam light bulb that it .
post #8 of 10 Old 12-21-2013, 09:29 PM
jfaulk
I know I'm a little behind the curve, but the link provided by "mycreativename" that references wjjeeps is exactly where I read it. I couldn't remember where I'd seen it, but once I started reading through that link, it refreshed my memory. Again, I know I'm not providing much help, but wanted to at least answer your question.
jfaulk is offline
post #9 of 10 Old 12-22-2013, 11:32 AM Thread Starter
FordExplorer
I got it fix just put black tape over the light and fix the problem
post #10 of 10 Old 12-22-2013, 12:24 PM
mycreativename
Haha that works!
Sent from my blimp fortress using my carrier pigeons.
