issues replacing battery - JeepForum.com
post #1 of 3 Old 10-17-2003, 11:02 AM Thread Starter
ccyoder
I'm planning to replace the factory battery in my 99 jgc laredo, which is listed as a 625-ampere battery. I can't find the 625-ampere rating in any aftermarket batteries that I've looked at. Is the 625 amperage necessary, or will I be find with a good battery from an auto parts store? Also, has anyone run into any computer/electronic issues after having disconnected the battery?
Thanks.
ccyoder is offline
post #2 of 3 Old 10-17-2003, 11:30 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
As long as you buy a battery that is listed in the part store as a replacement, you'll be okay. The ECU may take a couple of starts to relearn itself.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 3 Old 10-17-2003, 03:13 PM
Skyjacked97ZJ
A battery is a battery. Any automotive battery should work just fine. I personally use an Optima.
Skyjacked97ZJ is offline
Replacing battery cables danielrp ZJ Grand Cherokee Forum 20 05-17-2013 01:27 PM
replacing battery terminals Wuzz ZJ Grand Cherokee Forum 1 09-03-2009 01:02 PM
ABS Issues after replacing u-joint flinthills76 ZJ Grand Cherokee Forum 2 03-28-2009 04:35 PM
Tip for Bad Starter or battery issues tommer12 ZJ Grand Cherokee Forum 1 02-09-2009 11:06 AM
Battery meter issues... Dopalmer ZJ Grand Cherokee Forum 3 07-14-2005 07:41 AM
