Issue installing moog ssd107 SS - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Issue installing moog ssd107 SS
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 02-25-2012, 10:31 AM   #1
dlaporta
Purchased this SS through rock auto and I've come to realize that the hardware pack that came with it does not work with my 04 wj. Just to ask, this part should fit my truck with the right pack, right? Does anyone have this installed and came across this issue?
Also had an issue trying to remove that nut on the axle bracket so I took it to a local shop to see if they could remove it with an impact driver, and they rounded it out, but I managed to remove the bolt anyway. I should be ok just reinstalling with the same bolt and leaving that rounded nut on there?
dlaporta is offline   Reply With Quote
Unread 02-25-2012, 04:11 PM   #2
dlaporta
Bump
Unread 02-25-2012, 07:18 PM   #3
FrankTheDank
Go to an auto parts store with the old bolts and tell the guy u want new.ones.... Call the guys u ordered it from as well
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::Aussie locked 44A::4.56!!!::4'' IRO LA::33/12'' Retreads::4"BS wheels::IRO T case skid::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Winch Bumper::Smittybilt XRC8::
STOCK 97 ZJ LAREDO-Daily Driver
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline   Reply With Quote
Unread 02-26-2012, 06:06 PM   #4
Slo_Stng
Tried to install the same ss on my 04 wj today, and seems the tie rod bolt that comes with it is too short. Going to buy a longer bolt tomorrow, and see if that works.
Slo_Stng is offline   Reply With Quote
Unread 02-26-2012, 08:54 PM   #5
billzcat1
Chicken in a Turkey Suit
2003 WJ
I just installed an SSD107 about 2 weeks ago. There were two sets of hardware in the package, one larger set with thick washers for the various Ford applications it fits, and a thinner bolt for the Jeep applications. The hardware all installed just fine.
As for your nut...that nut is welded to the axle bracket. The outer shape is not important as long as the threads are good.
billzcat1 is offline   Reply With Quote
Unread 02-27-2012, 09:36 AM   #6
dlaporta
Thanks billzcat
I realized I panicked a bit- after thinking about it more I figured that out. All went together fine in the end.
To add, I'm pretty happy with the SSD107, it's a noticeable difference. Now I'm not floating all over the road!
