Issue with the 03 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Issue with the 03
RuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-10-2011, 06:28 PM   #1
DonRog
1997 XJ Cherokee
Question Issue with the 03
I have a 2003 grand cherokee and up in the left rear quarter panel behind the rear tire there is something that looks like some kind of pump and it is leaking oil that smells like rear end grease or 90 weight oil, can any one help me as to what it would be? camera broke or i would post a picture
thanks
1997 Jeep Cherokee XJ
DonRog is offline   Reply With Quote
Unread 12-10-2011, 09:30 PM   #2
Gran_Paradiso
2003 WJ 4.7L
2003 WJ
FWIW, I have the same smell from my drivers rear wheel area. I've had all my axel seals changed and its still there albeit its only after you stop. Brakes are fine too. The unit under the rear quarter I believe its part of the emissions system for the gas tank or there of.
Sent from my DROIDX using JeepForum
2003 WJ 4.7L LTD Quadradrive * Kolak 3" Catback exhaust with Flowmaster 70 and Magnaflow tip * Spyder CCFL Halo projectors * Raptor 4500k 35watt HID's low beams * K&N Drop box air filter * Bilstein HD shocks * Stillen Cross Drilled Rotors and Metal Matrix Pads.
Gran_Paradiso is offline   Reply With Quote
Unread 12-11-2011, 05:12 AM   #3
DonRog
1997 XJ Cherokee
did yours seem to be leaking oil tho?
Unread 12-11-2011, 07:51 AM   #4
WJWKXJZJ
2007 WK
I could be wrong, but isn't that area where the rear axle vent is routed to? You might be puking gear oil up the vent hose and it's dripping down over the vapor canister?
The item you see is the evap canister and a solenoid for the purging system. The tank vapor lines are fed to it, and a stainless line runs along the unitbody frame rail and into the driver's side of the engine compartment.
WJWKXJZJ is offline   Reply With Quote
Unread 12-11-2011, 09:10 AM   #5
DonRog
1997 XJ Cherokee
ok thanks
Unread 12-11-2011, 11:09 AM   #6
Gran_Paradiso
2003 WJ 4.7L
2003 WJ
So that's where the axle vent is? Didn't know that
